Question about Philips 200P4 (Silver/White) 20.1 in. Flat Panel LCD Monitor
Strips of 2 inch wide black and white, running top to bottom
2 inch black and white strips to the left running from top to bottom. on the left side
  • 157 Answers
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Posted on Jun 16, 2009
B&w 6800 lots of horizontal black line areas. also, a vertical white strip about 3/4 inch wide about 3 inches from left side of paper
Hi!
the best thing is to make a copy using the glass and not the document feeder!If there is no lines on the copy simply lift up the cover and on the left side of the glass will be a thin strip of glass,Clean it with a dampened cloth and all line and marks should be gone1
Good Luck!
Apr 02, 2011 | Brother MFC 6800 All-In-One Laser Printer
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Scanner error 5
Try this one open up the scanning lid, use a small allen wrench and pull the screw at the left side of the frame that holds a 1 inch wide by 12 inch long piece of glass. pot ur finger inside the housing and begin to roll the gear/rubber belt to move the scanner bulb assembly towards the left side as far as you can go. Then, turn the machine off and on.
If you are adept at printer repair, remove the right side cover, by removing the two screws in the hand hold area. pull the cover out at the bottom, using the handhold area, it will pop quite loudly. Once you get the cover off, you will find a large sheetmetal box with a row of connectors across the top of the circuit board. You do not need to remove the sheetmetal box to access the connector I am referring to. The four wire bundle I'm referring to has black, yellow, blue and red wires going to it. It's pretty much in the center of the row of connectors Be sure it is secure.
If the connector is securely inserted and no pinched wires are observed, the next most likely cause for this issue is a calibration stip for the scanner head inside of the scanner top. There are no spare parts for that level of repair. Opening the scanner top to repair it is likely to let in dust or debris and you won't find much that can be done if the calibration strip has moved or delaminated. The scanner top will need to be replaced. I believe the part number for the scanner top is Q3948-60191 unless it's been replaced with a newer part number.
that shud work if it doest contact hp....
good luck
Jul 12, 2009 | HP LaserJet 2820 Printer
Black strip 1.5 inches wide on right side of page
first, take drum unit out and make sure the blueish-purple colored plastic tab on top of drum is all the way to the left side. if thats not the culprit, then you are most likely looking at a bad contact image sensor or CIS.
hth,
ray
Apr 03, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
White block on left side of moniter screen
the screen has failed - i once had a screen with same problems :() order a screen from here newegg.com
Mar 16, 2009 | Computers & Internet
ADF copy with black streaks?
lift up your adf and locate the thin piece of glass, about an 1' wide, and clean real good with rag and windex. probably white out or some foreign material on that glass.
hth,
razors
Feb 27, 2009 | Brother MultiFunction Center MFC-440CN...
Part of my LCD screen is missing.
This sounds like you have a damaged LCD screen or dead pixels. I don't know anyway to solve this besides changing the screen.
The only other thing would be a motherboard problem meaning u have to change that but most likely its the screen.
Jan 22, 2009 | Computers & Internet
Screen Problem
Unfortunately the fix is a new lcd. The tab welds at the top of the lcd are not allowing that portion to work correctly. As these tabs are fused to the lcd you will need to replace the lcd. My Toshiba M105 is almost the same.(I Have 4" Gone) on the right side. so to use it I clicked and dragged my system tray from the bottom to the side. And shrunk my web pages to utilize tthe good portion.
I suppose I should replace it but being only 18months old the LCD's run about 160.00 USD.(sometimes I just hook up an external monitor.
Apr 16, 2008 | Toshiba Satellite P105-S6207 Laptop
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Philips 200P4 (Silver/White) 20.1 in. Flat Panel LCD Monitor Logo
162 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
