When the new replacement lamp and cage assembly (BQC-XVZ90+++1) are installed the lamp timer will not return to zero and the lamp replacement monitor appears on the screen instead of lamp 000H being displayed. screen bulb use menu still shows 2400 hrs - the point when we bought the new replacement bulb. we have followed the installation and resetting the lamp timer instructions carefully. can you suggest something. the projector worked perfectly otherwise.
Have a sharp projector XVZ90.Replaced bulb but timer needs to be manually reset by dealer. Does anyone know manual reset details ??Have a sharp projector XVZ90.Replaced bulb but timer needs to be manually reset by dealer. Does anyone know manual reset details ??
You can't post conmments that contain an email address.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Have a nice day!
Jerry
Lampdeng Limited
Have a nice day!
Jerry
Lampdeng Limited
Have a nice day!
Jerry
Lampdeng Limited
Have a nice day!
Jerry
Lampdeng Limited
First check your bulb properly matched with your projector. After changing the lamp reset the lamp hour (counting from 0hrs). Adjust the osdtransparency.
If u set the lamp properly then It may cause the lamp circuit need repair.
Have you got yellow lamp indication before change the lamp? If occur then you have been late tochange it. If you used it up to 2500hrs. then this problem may arise. Check those first if everything okthen may be the circuit have some problem, go to the nearestsharp authorize service center or visitwebsite.
Have a nice day!
Jerry
Lampdeng Limited
There is no problem here, the sharp projectors just do this until you enter the reset procedure. It comes on a sheet with your lamp. they differ from projector to projector. often involves hold down power and some arrows while plugging in the projector - that will reset the lamp timer and you will be away!
