Acts like the battery is dead but it is fully charged. Has been resetting the clock every time it is started and then today nothing. No lights, power locks, and nothing when the Key is turned.
SOURCE: Car won't start
Check the lever for putting the car in park/drive.
If the switch/sensor that detects where it is at (i.e. P, R, N, D, 2, 1) is broken or loose, it may think the car is not in Park and cars with automatic transmissions will not start unless they are in Park.
It might also be the starter is bad.
Ken P.
SOURCE: 04 pontiac grand prix wont start.
first remove the battery and take it to a auto parts place and have them check it. move on from there. if the battery is good the do a starter draw test. take a meter and hook it to your battery. now have someone try and start the car. if the voltage on the battery drops from 12.8 to below 9 volts then the starter is bad. if the voltage doesnt drop much at all then its prolly the solenoid both of which require starter replacement since most solenoids are on starters. if still nothing then check ignition switch. but before anything else ensure vehicle is in park. if it is in part use a meter to test neutral safety switch.
SOURCE: when i start car, clock and trip milege resets
Yes I would after if you have an amp on your stero make sure it is not on all the time.
SOURCE: 2002 Pontiac Grand prix wont start; unable to remove key
On many cars, if the battery is dead, it locks the key in the ignition. Put a battery charger on the car or replace the battery and give it a shot.
Good luck.
Thanks! The battery cable was the problem!
