Question about SanMax (HD-339-CB) (PTHD-339-CB) Drive Case
Mac can't find SanMax HD-339-CBB -- Blinking red light...
Hey all,
We had cleaners in the office over the weekend. Came in on Monday, and the front button on the external HD had been pressed in, green light on, and fan was running. (Looks like the stapler was pressed into it by accident.) Now, I've got a constantly blinking red light on the front button, and I can't seem to discover the drive.
Help, please! Running the latest Mac OS.
Thanks!
3 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: USB Connection Issues
Cat this is your earlier problem reworded - I can see now that this is a dual device. If you can use it that way in Firewire mode leave it at that. However - is it possible that this is a 'switchable mode device and you have not discovered the secret of how to. If there is anything like a manual with this check it thoroughly or get into the makers tech support team
Posted on May 24, 2007
SOURCE: USB Connection Problems
Jackboy, that wasn't a very good answer and it is apparent you are unfamiliar with the SanMax HD-338 External Hard Drive Case which has BOTH USB and Firewire connectors.
I don't have the answer to Redfire's question, but at least we need to understand her situation. She's not getting USB and Firewire confused. She's simply saying that when connected as USB Windows XP has trouble "seeing" the drive and when using her firewire connection off of the external case, she doesn't have this problem and is wondering why.
Jim B.
Posted on Nov 12, 2007
Instructions
From the manual:
Setting the Clock
1. Press and hold the Time Set Button until the display begins flashing
2. Press the Reverse or Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display
3. After setting the time, press the Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode
Setting the Calendar (It is important to set the correct date in order to use the 7-5-2 Alarm settings)
1. Press and hold the Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display
2. Press the Reverse or Forward Button to set the correct year, and then press the Enter Button. The unit will beep and the display will show the month and day. Again, press the Reverse or Forward
Button to set the current date
3. After setting the date, press the Enter Button or wait ten seconds to return to the normal display mode
Setting the AM/FM Radio Alarm
1. Press and hold the Radio Alarm Button until the settings and radio frequency appear on the display.
2. Press the Reverse or Forward Button to set the alarm time.
3. Use the AM/FM Band Button or the Memory Set 1-6 Buttons to select a radio station to wake up to. Adjust the alarm volume using the Volume Thumbwheel
4. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
5. After you have programmed the radio alarm, press the Enter Button or wait ten seconds to return to the clock display. The Radio Alarm Indicator will appear on the display, showing that the alarm is set.
Setting the Nature Sounds Alarm
1. Press and hold the Sounds Alarm Button until the settings and Nature Sounds Indicator appear
3. Use the Nature Sounds Button to select a nature sound to wake to. There is a choice of four sounds:
Sound #1: Ocean Surf
Sound #2: Forest Spring
Sound #3: Rushing Brook
Sound #4: Summer Wind
5. After you have programmed the nature sounds alarm, press the Enter Button or wait ten seconds to return to the clock display. The Nature Sounds Alarm Indicator will appear on the display.
Setting the Buzzer Alarm
1. Press and hold theBuzzer Alarm Buttonuntil the alarm setting appears on the display.
3. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
4. After you have programmed the buzzer alarm, press the Enter Button or wait ten seconds to return to the clock display. The Buzzer Alarm Indicator will appear on the display, showing that the alarm is set.
Dec 06, 2013 | Timex T309TT Clock Radio
Canon IP5200R printer. Green & red led`s flash 20 times, pause & repeat. print head will not come out of park position on righthand side. Fault occurred while printing a photo error 6500 displayed
Hello!
Error 6500 or green and red flashes 20 times, mean hardware error. Particularly, the Logic Board Assembly
There are two possible fix: first is to reset the printer's waste ink counter and the second is to replace the Logic Board Assembly (part # QM2-2733)
Reset the Waste Ink Counter:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a
function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
For technical help:
  • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Hope this helps!
May 18, 2011 | Office Equipment & Supplies
Try to get bose remote to control sky hd boxs need code and set up instructions thanks
To programme a Bose Cinemate remote control for Sky+ & Sky HD
  1. Press and hold the Setup button until all 5 green lights show
  2. Press SAT button
  3. Using number buttons, enter code 01175. The SAT button should blink.
  4. Press SAT again. You should now be able to control the Sky box.
Note: Use "Exit" for "Backup". Also there is no green button to access the planner on Sky+
Aug 27, 2010 | Bose Cinemate Digital Home Theater System...
Hey, this is the first time I am changing the ink cartridge but it doesn't want to come out, even after I press down on the green button. Why? Anyone know?
First open the front cover, you have to pull on the handel in the middle of cartidge with some force to take out of machine. You can put it down on a table, then press the green button to remove the grey toner cartridge out of the black drum unit. Then put new toner in drum unit and put back into machine
Apr 09, 2010 | Brother HL-2170W Laser Printer
When I press power button, only power button is lit green solid and nothing else happens...nothing on the screen...all black. No sound codes. Tried external monitor...nothing. CPU fan keeps running....
yes its motherboard. GPU has failed. Most likely you'll need to get your motherboard Reballed or Reflowed. I have found some reasonable business partners that do this service through ebay. usually runs 80-140 to get fixed. good luck!
Ruben
Jul 18, 2009 | Acer Aspire 5100 Notebook
Maxtor external HDD not detected by Vista
try to format it.it might need a quick format for you to use it. if still doesnt work check for the sata,pata cable that connects your motherboard.
Apr 30, 2009 | Maxtor Hard Drive
Tech Support Telephone No.
877-794-7977. Our hours are 8AM - 8PM Monday - Friday EST and 10AM - 7PM EST on weekends.
Nov 12, 2008 | Televison & Video
Day of Week
Yourl calendar year may be wrong. If the calendar needs to be reset hold down the month/date & time buttons. Press the up or down button based on you have to baclward or forward.
Nov 06, 2008 | Emerson Smartset Clock Radio
Refrigerator has started turning off on weekends for no reason
Does it start cooling soon after the office is opened? It is possible that it is in a defrost cycle right at the time that you open the office. Frost free refrigerators are control by a defrost timer which may be starting defrost soon before the office is opened. Defrost time is 18-22 minutes. Or the thermostat could be sticking in the open position while there is little or no door traffic. When you open the office and check its operation it could be what is restarting the system operation. If this is the case replace the thermostat.
Aug 11, 2008 | Whirlpool Refrigerators
Setting the days on the alarm?
Hold the alarm button down and press the mode button to change the days of the week you want the alarm to go off.
Oct 11, 2007 | Emerson SmartSet CKS1850 Clock Radio
SanMax (HD-339-CB) (PTHD-339-CB) Drive Case Logo
98 people viewed this question
Top SanMax Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a SanMax Computer and Internet Expert? Answer questions, earn points and help others
