Question about HP Pavilion DV6500T Notebook
Failure to start
I have a HP Pavillion dv6500. It will not start up at all. I noticed the battery was discharging last night and would not charge despite being plugged in. I checked all the leads and the power input light (blue) was illuminated suggesting that the power was getting to the laptop at least. I think it is the battery but i am surprised that it will not work even when plugged in - does it require the battery to be present and working does the laptop need the battery to be able to take a charge - will a new battery resolve the problem?
  • 1 more comment
  • HippoRabbit Jun 16, 2009
    No, it does not work with the battery removed at all, nor does it work with the battery in but the power light on the side where the power lead plugs in continues to work with either battery in or out. The only difference between the battery being in or out is that with the battery in the little blue light on the front flashes when i press the 'power button' where with the battery removed the little blue light does not flash when i press the 'power button'. Is it a feature of this laptop that a working battery has to be present for it to work when it is plugged in - last night it continued to work right up and until the battery had completely discharged (showing 0% of charge remaining) but would not charge with the power lead plugged in.
    My feeling is that the battery has snuffed it and that this laptop requires the battery to be in and chargeable for it to work as it takes its power from the battery whether plugged in or not. I am getting a new battery tomorrow - if that works i will let you know.
  • HippoRabbit Jun 17, 2009
    The new battery came and it worked for about 7 minutes (completely booted up in the normal way to desktop) long enough for me to see that the new battery had 28% of power available - I was just about to plug it in to charge the new battery but before i plugged in the lead the laptop shut down - now with new battery or old battery it will not fire up at all, lead plugged in or not.
    I checked the power lead on another older laptop and that laptop works with the lead.
    If it’s to do with memory or processor etc why would it work at all with the new battery that seems really odd...
    Sounds terminal - voltage regulator on Motherboards issue. If it is terminal how can i get the very important info from the hard drive - could i set it up (the hard drive) as a secondary drive on my desktop or would i be better removing the hard drive from the laptop and putting it into another laptop - won't be the same make. Alternatively i could buy another HP dv6500 second hand and put the hard drive into that couldn't I?
  • 157 Answers
Will the laptop start if the battery is removed and just the charger plugged in? I would remove the battery and charger for a few minutes and try it with just the charger plugged in. Unfortunately it sounds like a hardware fault. Let me know how that goes. The other thing to try is removing the ram and then putting it back in. this will solve alot of problems like this.
Posted on Jun 16, 2009
  • 2 more comments
  • Caleb Judd Jun 16, 2009
    No It does not require a battery to be in to start.
    You can try charging it for about 6 hours then try start it but i doubt it will help. Might help to reset the laptop memory. there maybe be a pinhole on the bottom otherwise the cmos battery would need to be removed.
  • Caleb Judd Jun 17, 2009
    Its a problem with your voltage regulator circuit on the motherboard, I suspect if you charge either battery to full on another laptop then run it on yours it will work for a while, but the voltage from the power adapter is not being regulated properly. is there another laptop you can charge the batteries on to test it?
    If this is the case then the laptop should only start up if the battery is in and charged and the power adapter is not connected.
  • Caleb Judd Jun 18, 2009
    You can put the hard drive in a desktop but you need an adapter for it. it is easier to buy a laptop hard drive enclosure and put it in there then plug it into a usb port. or if you can find a similar laptop that will work too.
    Have you been able to charge the battery on another laptop and test it?
Can the car alarm kill your battery but you can start the car but after you turn it off battey died again
sure, if you let the alarm drain the battery, this can destroy any stock battery.
The car batteries are not like golf carts and are not deep discharge rated. (so can be damaged)
so charge the battery, if it wont hold a charge, it is bad.
if it discharges silently, and darkly parked , that is phantom discharge
if is discharges , driving that is a engine charge system failure.
parked over night discharging is phantom discharging.
if the alarm goes off and stays in alarm , then dont use, it.
if the battery is happy with the alarm defeated then the Alarm is bad.
The battery measure 12.6vdc charged,(rested) "voltmeter"
and running measures, 13.3 to 15vdc at idle.
this one tool can solve this problem
http://www.walmart.com/ip/Equus-Innova-3721-Battery-and-Charging-System-Monitor/15137663
cheap.
Dec 05, 2014 | 2000 Chrysler Cirrus
Nikon coolpix 59500
The most likely cause is a bad battery. But before you throw it out, try discharging it and then recharging it.
Probably the fastest way to discharge the battery is to turn on the flash and start taking pictures. It doesn't matter what you take pictures of, you're going to throw them away afterward. Just point the camera away from you and start clicking. Take a hundred pictures or so, or until the battery level drops below 25%, or the flash recharge time gets very long. Note the battery level, then recharge it overnight again and see what the level goes to.
Jan 17, 2014 | Nikon COOLPIX Cameras
Forgot login name for computer running windows vista
The name should already be on the welcome screen and then you would just need the password.
Sep 17, 2013 | HEWLETT-PACKARD Hewlett Packard Techno...
Hp pavillion zv6233nr
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged state for long periods.
May 05, 2013 | HP Pavilion Computers & Internet
I have a dv6500 and it work only whit te battery. the ac adapter dont charg the battery and the pc dont work and the charger its ok. maybe a fuse?? tks rgds
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 19, 2011 | HP Pavilion dv6000z Notebook
I bought a replacement hp battery for my HP Pavillion zv5000 a year ago. It was working fine for about 6-8 months. Then, it seemed to stopped storing energy even when the charging light stopped and...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 08, 2011 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My battery is not recognised and doesn't charge
Check the battery status manually
To accurately measure the condition of the battery, the PC cannot be used during this test. This method will Test the battery by completely charging the battery then will determine how long it takes to discharge the battery. This test is done while the PC is operating in the Safe Mode and not being used for any other action. This test will require 1-3 hours depending on condition of the notebook PC. The PC cannot be used while you perform the following steps. Completing all the following steps will also calibrate the battery so that the power meter reading are accurate.
  1. Connect the AC adapter and allow the notebook to charge until the battery is charged to 99% - 100% of capacity.
    • To determine the percentage of battery power, with the notebook operating normally, right-click on the c00586951.jpgpower icon in the system tray, and select Open power meter . The Power Status is displayed.
  2. Shut down the notebook PC when the battery has charged to capacity.
  3. With the notebook turned off, connect the notebook PC to the AC power adapter that is plugged into a working wall outlet.
  4. Press and release the Power Button to start the computer.
  5. Press the F8 key several times when the HP Logo displays.
  6. When the Windows Advanced Startup Menu displays, select the Startup in Safe Mode option.
  7. Notice and record the current time as the Test Start Time with a fully charged battery.
  8. Remove the AC power adapter cable from the notebook PC.
  9. Allow the battery to discharge completely until the notebook PC turns off.
  10. Notice and record the Completely Discharged Time.
  11. Subtract the Discharged Time from the Start Time to calculate the Elapsed time.
  12. Record the time for future comparison or to provide to an HP support specialist if you suspect the battery is defective. NOTE: As with all batteries, the maximum capacity of this battery will decrease with time or use. Loss of battery capacity will vary depending on the product configuration and usage, including but not limited to: product model, applications running, power management settings, and product features.The battery warranty does not cover natural deterioration of battery capacity. Your battery is only warranted from defects in materials or workmanship resulting in failure.To determine if your battery has had a warranted failure you may be required to run an HP diagnostic.
After performing these steps.
--- Remove the batter and power cord
---After 5-10 mintues insert the batteryu and comment the AC Adapter and then Press the power button on the notebook for about 5 minutes .
If there is any power issue the issue may fix.
Jan 08, 2009 | IBM ThinkPad R40 2681
HP Pavillion dv6500 Notebook. Power light coming on when connected up to charger but no charge going in.
I just fixed my friends dv6500
it had same probs as mentioned above
the probs i found : shorted schottky diode marked LG = smd10k45
                           shorted n-ch mosfet      marked 702 = 2N7002
                           defect smd cap
All these are placed just below the battery connector on mobo
see page 128 of service manual
replaced these smd's and laptop worked again
the damage was caused by overheating of the smd's
could be you have the replace other smd's surrounding these mentioned above
depends on how hot it was
hope this helps
Greetz
RzAn8
Nov 13, 2008 | Computers & Internet
Hp dv6500 Notebook
u can go hp support site select download then product (hp pavillion dv 65000)choose your o/s i.e win xp and download the audio driver or go to this link http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3380543&lang=en&cc=us&prodTypeId=321957&prodSeriesId=3369402&taskId=135 select win xp then go to audio driver and download
May 17, 2008 | Computers & Internet
HP Pavilion DV6500T Notebook Logo
343 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
