Question about ASUS Computers & Internet
4 way system from master phone socket I have broadband lights flashing intermittently at sporadic intervals on new router Ethernet light follows broadband light Line has been checked by Plusnet and no fault found so it may be internal wiring or connections How do I repair
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
This light is replicating the spordic exchange of data, and the light is designed that way. This means your braodband and modem are both functioning perfectly.
Posted on Jun 18, 2009
I have a (like) phone chord and can't find where to put the other end. We have it plugged into the back of the router, need to know where to plug the other end.
Hi
It depends on which country you are in.
It depends what Broadband wiring setup you have.
It depends which type of cable you are talking about (see images 1 and 2 below)
In some countries, the RJ11 to RJ11 cable goes from this device into the phone Socket of an ADSL filter. One RJ45 to RJ45 cable goes from the Router into the Ethernet Socket of the ADSL Filter. Another RJ45 to RJ45 cable goes from the Router to the Computer. The ADSL Filter then goes into the Phone socket in the wall.
You need an ADSL Filter in every Phone Socket that has a telecommunications device attached to it (Fax Machines, Answering Machines, TV Set Top Boxes, games Consoles etc.). The ADSL filter separates Telehone, Voice & Fax Data traffic from Broadband traffic and allows all to share the same phone line with out conflict.
See Network Diagram below.
In some countiries or wiring setups, the RJ45 to RJ45 cable form the Router to the Wall does not need to go via the Phone Socket and can go directly into its own dedicated Ethernet Wall Socket.
If this answer helps you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and helps us explore the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa
IMAGE 1: RJ11 to RJ11 or ADSL MODEM or BROADBAND or TELECOMS or TELEPHONE Cable
virtual_a_4.jpgIMAGE 2: RJ45 to RJ45 or CAT5E or LAN or ETHERNET Cable
DIAGRAM 1: Typical UK Home Broadband Network Diagram
Aug 30, 2011 | Linksys Wireless-G Broadband Router
When I first started using this modem, it worked great and easily worked well with my Belkin router. One day when I came home, the modem was only flashing the "power" light was flashing and I had...
Flashing power light on Router is sign of hardware failure As mentioned, you have already reset the router
You can try to hard reset the router one more time
Follow this procedure
1. Press the reset button with some paper clip 2. Wait for 10 Secs 3. Turn of Power to the router (While Reset button is still pressed) 4. Wait for 10 secs 5. Power on router 6. Wait for 10 secs and then release the Reset button
While doing this make sure reset button is pressed continuously start from Step 1 - 6
Check if Power light still blinks
If No - you can setup router like before and it will work If yes - Buy a new router or get it replaced if under warranty
Jun 29, 2011 | Arris SURFboard SB5101 Cable Modem
Router keeps dropping connection
the problem might be with your dsl line. Check to see if it happens with all phones, sky and non broadband equipment removed from your phone sockets. if it still drops contact your isp.
Apr 09, 2010 | Belkin F5D8236-4 Router
Just bought PB Ixtreme x5620. i am trying to connect my virgin broadband to the pc. i have netgear router which has the yellow cable in the moden and router and the blue cable in the PC and router. i can...
Can you supply more detail of your network setup? You have a broadband modem, a seperate router and the PC.
For this setup cabling should be ....
1. Phone Socket (Pref. Master socket) to ADSL socket on modem
2. Modem LAN socket to Router WAN socket
3. Router LAN socket to PC Ethernet socket
Usually in this configuration you will have to switch off DHCP on either the modem or the router as they may both be trying to supply IP addresses to your PC. I would suggest disabling DHCP on the router and leaving the ADSL modem to supply IP addresses. If you do this you will have to setup the Router with a valid fixed IP.
Have fun!
Cheers,
Ripface.
Oct 25, 2009 | Computers & Internet
Internet connection sporadically interrupted. "Router problems". Green lights on router flash in unison. Problem seems to be worsening. Do I need a new router?
might be the router. try plugging the cord that goes to the input of the router directly into your computer and see if still same problem.
Oct 16, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Can't get my BL-PA300KTA to connect. I have plugged it in and pressed the Setup buttons (within 3 seconds Mater and Terminal). The PC, LAN, and Master lights are ligting up as they should (I believe), with...
I use these and the previous model without any issues.
1. They must be plugged into the wall socket. It's okay to use an extension cord between the adapter and the wall, but never a surge suppressor or UPS
2. The master need to be connected to you router
3. To test your connection do the following
-Plug the master into the wall at the router location
-Plug the slave into the outlet where the computer will be
-Press and hold the setup button on the slave unit only for 3-5 seconds
The leds on the slave will flash for a second or two and then turn solid.
The number of solid lights you see tell you what your connection speed will be 0-no connection, 1-<10MB , 2=-10-30MB, 3->30MB.
I always unplug the ethernet cables from the adapter when testing, but I don't know if that is necessary.
I have never gotten less then 2 leds in my house, but it's new.
Sep 01, 2009 | Panasonic Network Camera HD-PLC Bridge...
My linsys wireless g broadband router appears to
Check your power adapter with a digital multimeter. Make sure the voltage is no higher than .5 volts than what's listed. If the voltage is malfunctioning and it gets to high, it can damage the ethernet port and more on your system if it is connected wired.
Aug 09, 2009 | Linksys Wireless-G Broadband Router
Broadband yellow light
yellow light on broadband keps on flashing , and my phone has a clicking noise
Jan 08, 2009 | 2wire 1800HG Router (RG1800HG00)
How do i configure my Belkin router to work with Sky broadband?
I'm not into hacking what I cannot find on ISP's sites
From what I can gather from the Sky Broadband site reading the manual installation procedures -- the process is pretty much automatic when it comes to installing their equipment leaving no clues as to how they configure it. What is the model if the Belkin router? Options probably exist to attach your device to theirs either as a router (establishing a second network behind theirs) or an access point joining as a member of their network - meaning there would would be two wireless networks in either case in the house (as there are no indications I have found on the site that the provided the sky router can be configured in any way such as turning off wireless). At least according to the documentation the sky router's wireless is running WPA-PSK security / encryption which is good -- and the documentation for attaching non-sky wireless adapters appears to be documented here.
Sky Setup
Dec 15, 2007 | Computers & Internet
Broadband connection
For the given computer Advent T9401 the following page indicates is has an ethernet (wired) network adapter - a wireless one to apparently.
http://www.ciao.co.uk/Advent_T9401__6476753#productdetail
If the question is about the router a manufacturer and model number will be required.
Dec 10, 2007 | Computers & Internet
Computers & Internet Logo
74 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
