Question about Hotpoint 21.7 cu. ft. Side-by-Side No-Frost Refrigerator with Dispenser CSX22GRBWW
Sid By Side Freezer Icing and Fridge not Cold
Hotpoint CSH22GR side by side fridge. Believe issue to be defrost timer. Getting ice in freezer and fridge not cold. Last time I completely defrosted unplugged and drained. Turned back on and then it worked for few months. I have to figure if the timer was totally dead would freeze up sooner than that. I am thinking it is intermittent. If it is the timer not sure where it is. My thought was to locate it and force into defrost. If the coil comes on then have to think the thermostat and coil is ok just the timer having issue and only coming on sometimes.
  • gdlove2 Jun 17, 2009
    So would you think the thermostate is bad. Everything I read says that the timer is the most likely suspect and most likely to go. Thoughts? Or do you think there is no timer in the unit and just a thermostate. I am not sure. I have not been able to locate either as of yet.
    Yes it does one for fridge and one for freezer. Thing is if I turn the dial the fridge will turn of or on so I would have thought that the thermostate was working. A friend who used to do appliance repair but lives afar is the one who suggested it may be the timer that puts the unit into defrost on a cycle. Is that not possible?
  • 159 Answers
Most fridges in s.a the defrosting is done by the thermostat if the fridge does not have a pc board
Posted on Jun 17, 2009
  • shaun greyvensteyn Jun 17, 2009
    do it have a knob to turn it colder if it does that is the thermostat
  • shaun greyvensteyn Jun 18, 2009
    if the motors put off. if cold it can be that the defrosting element is dead or the thermostat. if not working with a pc board
I have a side by side fridge/freezer. Occationally the freezer side warms up and the fridge side starts icing. It happens sporatically. It is a hotpoint model hsm25gftasa. Tried giving it more air
The defrost timer also turns on heater strips buried behind the metal parts that the door gaskets touch. It may be you're just witnessing the defrost cycle. If you have lost power for a time, that affects the clock time of day the defrost cycle starts. I'd look at the defrost timer and reset the time.
Oct 01, 2014 | Refrigerators
I have a Sub zero refridgerator 590, the refridgerator side is not getting cold, and it's icing up inside where the fresh foods are stored, yet the freezer is working fine. Please help
The freezer coils are iced up and that is blocking the sir flow to the fridge.... You have a defrost problem and that is causing the refrigerator to be warm...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
My hotpoint freezer compartment is icing up.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Nov 12, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Freezer stays cold, refrigerator does not. icing under back panel in freezer
heatman101
Nov 01, 2010 | Hotpoint HSS25GFP Side by Side...
Freezer works good, refrigerator does not get cold
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Sep 08, 2009 | Hotpoint HSS25GFP Side by Side...
Fridge isn't cold, but freezer is working fine
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 21, 2009 | KitchenAid Refrigerators
Fridge side is not cooling, freezer side is fine
Aug 08, 2009 | Refrigerators
We had a power outage and top half will not work
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
MSD2454GR Side by Side refrigerator- freezer side fine, refrigerator side will not cool below 50 degrees; lots of condensation
Jul 01, 2009 | Maytag MSD2454G Side by Side Refrigerator
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Refrigerators Logo
328 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
