Question about Foxconn 6627MA-RS2H Motherboard
Motherboard memory capacity.
I have a Foxconn P4M800P7MA-RS2H motherboard. The only manual I have says that it should be able to recognise 2GB of 533MHz memory. However when I installed this memory it is only recognising 1GB. Is there a way I can force it to recognise the whole 2GB?
thanks
  • 334 Answers
The motherboard will automatically detect it, make sure that you always use the same manufacturer, speed and size ram chips, don't mix and match. Go to this site and run the scanner and it will tell you what you have and what exactly you can put in it.
http://www.crucial.com/
Posted on Jun 16, 2009
I want to have a diagram of motherboard (Brand - Foxconn, Model - N15235) thanks
try here.http://www.motherboardpro.com/FOXCONN-6627MA-RS2H-Socket-775-Motherboard-p-203.html.or here http://www.techfuels.com/motherboards-memory/339-foxconn-6627ma-rs2h-motherboard.html.
Aug 09, 2011 | Foxconn 6627MA-RS2H Motherboard
I NEED MANUAL FOR P4M800P7MA-RS2 MOTHERBOARD
Here is the link to your manual (http://www.foxconnsupport.com/download.aspx?models=en-us0000138&category=C000000001&series=en-us0000002&keywords=&sort=Motherboard%20Manual)
Feb 12, 2011 | Foxconn P4M800P7MA-RS2 Motherboard
Hi I have Foxcoon P4M8007MB Motherbaord which has 1Gb memory (2 X 512 MB DDR2 installed) I have just bought 1Gb Kingston Value memory KVR533D2N4/1G X 2 Modules to upgrade to 2Gb ram but windows Ultimate...
Check out mo bo specs - you may have exceeded mo bo capacity. Or try a different memory stick - all memory are not created the same - some will work in one machine and not another. Experiment if you are within specs.
Sep 18, 2017 | Foxconn P4M800P7MA-RS2 Motherboard
DDR2 RAM ENQUIRY
Dear Sir
*********** Board is :Foxconn P4M800P7MA-RS2
Max Supported RAM : 2GB DDR2
Supported RAM speed: 533 MHz • 400 MHz • 333 MHz • 266 MHz. I think it deffinately solves your problem.If you have any problem post your comment with more information.
Good luck
thank you for choosing Fixya
MPN P4M800P7MA-RS2
Supported RAM speeds 533 MHz • 400 MHz • 333 MHz • 266 MHz
Aug 20, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
PC Motherboard Query
Hi there
This Socket 754 board will accept up to 3GB of DDR 400 memory and an 8x AGP video card
Thanks for Using Fixya
Jan 13, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
P4M800P7MB RS2H Foxconn motherboard and 2G memory upgrade
the 1gb memory modules need to be low-density ie chips on both sides. the motherboard can only recognise 512mb on each side of the memory module.
Jun 01, 2008 | Computers & Internet
Please help me in my RAM
Hi hope13,
you had it correct the first time. The DDR2 533MHz memory should be in the Blue slots. When using two DIMMS the motherboard requires the DDR2 533MHz memory be of the same size, brand & speed. For you to get a blue screen has nothing to do with you're memory. If there was a problem with you're memory, you bios would let you know by beeping a series of repeating beeps. Blue screens are usually caused by software & some hardware like you're hard drive. If you have data on you're hard drive & you do not want to erase it by re-installing windows fresh (That includes a must format), than I can suggest you download this software from this site. Click on the link.
http://www.ultimatebootcd.com/ Read what the software can do for you. If you do not want the software. Than break out you're windows CD & load it into you're CD-ROM drive. Boot the PC to the CD-ROM drive & in-stall windows. You're PC will function again when you finish installing windows & you're motherboard driver cd.
Good Luck!
I would have posted sooner but I though another was answering you're question.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 14, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Memory upgrade from ddr 256mb to ddr2 1g
there is a jumper setting to slect which type of memory you want to use, check your manual for details on how to change it
1> enusre the rams are in correctly
2>ensure your main board supports the amount of memory and the speed of the memory
3> verify jumper select to correct memory type is set correctly
if the main board aint compatable with the memory you brought that will cause the same problem
Jan 02, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Doesn't boot with 3Gb of ram....
Your board can only handle 2Gb of total memory.
2 x DDR2 SDRAM DIMMs, Dual Channel DDR2 533/667/800.
Check your manual.
Dec 29, 2007 | Foxconn 6100M2MA-RS2H Motherboard
Foxconn 6627MA-RS2H Motherboard Logo
458 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
