Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Cannot keep bike running after it is warmed up
Bike fires up real good, idles real good, but when i drive it, it will stall out and backfire some times. acts like it's not getting gas. thank u, dave
  • timothyjones May 11, 2010
    year/ model etc? if your ign module is in the "cone" probably showing a bad internal connection when it warms up; very common; to test you can run it in garage and heat up cone w/ heat gun / hair dryer for a few minutes if it dies; replace module; make sure a fan is on the engine though; you don't want to cook the motor; just the module
  • lacoy May 11, 2010
    what kind of bike, ignition system, and is it carbed or injected
  • 116 Answers
Kinda tough not knowing what your rideing wether its injected or not but it sounds more like coil connections or camsensor
Posted on Jan 05, 2010
When to adjust idle
If you can keep the bike running long enough to get it warm with and with no choke then that is when you should adjust the mixture,
First though start by adjusting it cold so the screw is set at about 1.5-2 turns out then run till warm set idle at around 1500 revs and adjust until it just starts to lift the revs then back off a quarter turn
May 02, 2013 | Yamaha Motorcycles
So i've recently run into a problem where the bike
If it was a two cycle I'd say it was clogged exhaust ports. But you have a pretty exotic bike. So I guess it's a timing issue dealing with the exhaust Ox sensors.
Aug 30, 2012 | Cars & Trucks
Car stalls after warm up, wont idle, surges from idle to highway speeds
Without knowing what car it is ...make. model and year this is a very vague question. A quick and dirty educated guess sounds like your timing has jumped ... if it's a timing belt, open the cover and check the timing marks ... or if it runs put on a timing light and look where the timing is ... sounds like it's firing after top dead center.
Nov 05, 2017 | 1990 GMC S-15 Jimmy
Bought the Bike Used from a HD Dealer 2004 XL1200C Sportster. 2400 Miles 2nd time I took the Bike for a ride It was Slamming into Gears Very Loudly, Had the Clutch adjusted and Gasket Replaced, Next Time...
check for the pinched vacuum line at the carb,, sportys are hard to locate because they are tucked in way behind , it ay have come disconnected, unless there is a load on the motor it will idle fine, add a little load and you get the feeling no fuel is getting through unless you rev it up
Jul 01, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Starts but takes a very long time to warm up. continually stalls when throttle applied. have to keep feathering throttle to keep running . spits ,sputters , backfires until fully warmed up
ColdI engines require a richer mixture to operate smoothly...so they have an enricher (aka choke).
If you are finding you need to keep the choke on longer.....you may have a lean mixture than normal.nother
Start by inspecting the carb and intake manifolds for any leaks (loose fittings....cracked hoses) that could be drawing in air, leaning the mixture.
Another common issue with bikes that have sat over winter...is plugged idle jets.....the fuel varnishes the tiny orifices in the carb. You could try a product like Seafoam in the fuel tank....run it abit to get the treated fuel in the carbs then let it sit overnight...allowing time for the chemical to work. Since the bike runs fine warm...this may clear things up for you.
Apr 05, 2011 | 2000 Yamaha V Star 1100 Classic
93 1200 evo, rough idle, stalling, back firing while coming to stops (using the bikes motor to slow down). power knocks when starting from a complete stop
Sounds like a combination of things. First, are you using high octane fuel? If not, try a couple of tank fulls of that. You mentioned "Power Knocks" when starting off from a complete stop. This is typical of detonation due to low quality fuel.
As for the backfiring and stalling. The engine should idle at about 1000 RPM or so. If it's idled lower thant this, stalling is a possiblity not to mention poor oil of the bottom end. The backfiring could be caused by an air leak into the exhaust system. The mixture in your exhaust system should be overly rich for combustion when you backing down using the engine. If the system is sucking air in at a joint sometwhere, it leans the mixture into a combustable mixture and it ignites causing the back fire. If you've removed the "anti-tamper plug" giving you access to the idle mixture screw, back it out about a half turn and see if that helps.
Good Luck
Steve
Jul 30, 2010 | Harley Davidson XL 1200 C Sportster Custom...
Engine stalls when put into first.No slack on clutch cable. Bike not used regularly.
check your idle speed.you should have about 1 cm of free play in the lever.also does it start up agian and are you able to drive it if not check your side stand switch
Oct 18, 2009 | 1994 Yamaha XV 535 Virago DX
Car not idling adn stalling when it is cold
sounds like the idle control vale is sticking when it is cold. It is located on the throttlebody right at the air inlet
Feb 24, 2009 | 2001 Mercury Sable
Lands Phones Logo
328 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
