I ordered them (Acct No. 11190931) 01/30/14, pad with chk #1473, dtd 2-10-14. Product was a nice size, however, was delivered on my doorstep 2 wks ago - frozen. I immediately unwrapped them and put them in the window with other plants to see if they would pull out of it. I report that today they are totally dead and wilted without any hope of survival. I would still like replacement of these two items without further charge due to a more appropriate "sending" time for S.D. conditions. Thank you - I hope to hear from you very soon to rectify this situation.
SOURCE: 1999 Chev 2500 want start. Replaced wires,plugs,
check fuel pump pressure....GM is known to have faulty ones that work after started and will run but wont send enough on cold srarts...Good luck...Lee
SOURCE: I just bought my son a 1996 Jeep Grand Cherokee
the alternator failed this is usually a chrylser and jeep dodge isue the bearing fails and the alternator quits charging the if the light comes on its usually alternator but on some jeeps the light dosent come on because it reads that it is charging
the other thing that it could be is the battery shot on ya the only thing you can do to see if its a good battery do a battery acid test
SOURCE: the electrical system is totally dead
Check your battery leads and make sure you have good clean connection first. If that doesn't solve the problem, start looking for wires that may have been misplaced during the work on your car and see if you can spot any melted wires. Also, check all connections on your altermator and battery status. One of these should lead you to the problem.
If you know for sure the battery is charged, it could be a dirty battery cable end, or a blown maxi fuse.
Could also be a bad ground connection.
