Question about Sony Playstation 3 (PS3) Console
My ps3 wont turn on
I turn on the power switch in the back (red Light comes on solid).
When i hit the power button i can hear the fans start up for 1 second then the light blinks yellow the system beeps three times and the system shuts down leaving the light blinking red. i have a game in it that i cant eject because it wont stay running long enough. can i change the cable, or do i have to deliver it for service?
    Novelist:
  • 174 Answers
Hi There,
Your Processor needs reflowing (re soldering on the board) as the system over heated, it caused stress on the solder joints underneath.
Sony charge £150 and give a month warranty to repair it.
We charge £60.00 and give a 6 month warranty.
FixMyConsole
Posted on Jun 18, 2009
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: my ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
Posted on Jun 16, 2009
My ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Tip
Fix the 80010514 error on your PS3
If your Play Station 3 (PS3) gets the 80010514 error somewhere, you can try this to resolve the problem:
1. Make sure that the power indicator on the Play Station 3 system is solid red. To do this, press and hold the power button until the PS3 beeps and the light blinks. Once the light has turned solid red, turn the power switch in the back off.
2. Turn the switch back on, then press and hold the power button.
3. Keep holding the power button even after you hear a short beep after 5 seconds.
4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
5. Press and hold the power button again.
6. Continue holding the power button even after you hear a short beep after 5 seconds.
7. Release the button when two short beeps are emitted after 7 seconds.
8. As instructed by the on-screen message, plug in the controller and press the PS button
9. Select restore Play Station 3 system.
This should not affect any of your save games, demos, etc. but just to be safe you might want to back up to an external USB hard drive.
To backup saves, go to the Play Station 3 Save Data Utility, select the save you wish to copy and hit the Triangle button. Copy should come up as one of the options. If it does not then the save game is copyright protected and can’t be copied. If you can copy it, make sure you have a USB drive attached and copy it to that.
on Feb 02, 2010 | Video Game Consoles & Games
I was playing online yesterday and my console shut down.today it still wont turn on.the red light comes on and when i press the power on the light turns green for a few seconds but then goes back to red.my...
You can try the steps below. Its from PlayStation Forum:
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
May 18, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont come on the red light on but wont turn on and its not overheated
well as cookies.
I wish you good luck.
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
Wont fully turn on
You can also try the steps below. Its from PlayStation Forum:
well as cookies.
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
Alright you need to put your ps3 in what is called "safe mode". First make sure there is no disc in the ps3, then turn off the ps3 in the back(main power switch), turn that switch back on, then hold the power button in front until you hear a total of 3 beeps, then let go, the light will be red, hold the power button again and you will hear 2 beep then a quick double beep, let go of power button and the light should stay green. A menu will appear, try all option working your way up from option 1 until it works. If you go through all 6 option and you are still having issues call 1-800-345-7669 to have your ps3 serviced
Aug 10, 2009 | Sony PlayStation 3 40GB System
Ps3 wont power all the way up
if you have moved your ps3 to a different tv or something, the video setting can get messed up, thus having to reset the video settings. here are a few steps to do so.
1. put your finger on the reset button and wait until the ps3 is in standby. (Keep holding your finger on it, don't let go)
2. turn off the ps3 completely by switching off the power switch (make sure your still holding your finger on the reset button)
3. turn your ps3 back on (while still holding the reset button) and you will hear a beep. keep holding the reset button until you hear a second beep. let go of the reset button as soon as you hear the second beep
this should reset the video of your ps3. ive done this to my ps3 before because when i was installing linux i almost screwed up my ps3. when i turned on my ps3 no picture or sound would appear. so i called sony and this is what they told me to do and it worked.
Jul 09, 2009 | Sony PS3 40GB Best Sellers Bundle Console
My ps3 wont turn on
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
357 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
