Question about E-Machines T1090 PC Desktop
Jumper settings the mother board has 8pins please tell me how to set the jumpers correctly i seemed to have disable the video
    Problem Solver:
  • 6 Answers
Re: jumper settings
It all depends on the motherboard model and manufacturer. You may want to lookup motherboards manual on google.
Posted on Nov 12, 2007
0 characters
3 Points
How to disable an onboard video card and install another video card
There should be a jumper on the motherboard OR a setting in the motherboard bios. Try looking through the bios menus first... If there isn't a way to disable, get the model of the main board and look at the jumper diagrams online.
Apr 24, 2012 | eMachines ET183105 PC Desktop
Someone gave me a dell optiplex 240 pc they did not have the password i have tried removing the password jumper and also the battery and still it asks me for a pass word help
Make sure you remove the jumper with the power OFF (not connected)
Disabling a Forgotten Password
NOTICE: This process erases both the system and setup passwords.
1 Open the computer cover.
2 Remove the jumper plug from the PSWD jumper to disable the
password feature.
See "Jumper Settings" to locate the password jumper (labeled
"PSWD") on the system board.
3 Close the computer cover.
4 Reconnect your computer and devices to an electrical outlet, and then
turn them on.
This erases the existing password(s).
5 Enter system setup and verify that the password is disabled.
Jul 14, 2011 | Dell XPS 400 PC Desktop
How to unlock my dell desktop computer
Open the cabinet after disconnecting all the connections form the power.and look for the C mos battery on the mother board and remove it,and then after few minutes place it again.
You can either use a jumper on the motherboard and
look for jumper and set in the normal position. Although the jumper is small, it should be easy enough to remove it with just your fingers.
Please rate me if this solution works for you
Thanks......Have a great time
Jul 03, 2010 | PC Desktops
Mobo Jumper settings for BX pro PC100 Motherboard
*********** board sounds like the same as a Fujitsu board.
moz-screenshot-1.pngthe user manual can be found at diplodocs
It shows the jumper settings and board layout for a Fujitsu motherboard.
I hope this helps. Have a great day
Mar 18, 2010 | PC Desktops
Disabled video driver. Now unable to reboot emachines T5246
reset your bios settings put cmos cell for 15 minutes. also u can reset bios with jumper settings.
then remove meory card then check beep.
then connect allconnection then try.u can do it man.
Jan 05, 2009 | E-Machines eMachines Desktop PC
I have an emachines etower 433i with onboard video. I've installed a separate pci video card, but I don't know how to change the jumper settings on the motherboard to disable the video chip. On the...
Go into >my computer>properties>device manager>graphics.You should be able to disable your on-board graphics there. Be sure your computer boots from the new card before you do this.
Dec 17, 2008 | PC Desktops
I recently upraded my computer with an Asrock Penryn1600SLI-110dB motherboard with an Intel CORE 2 DUO E4600 processor. The symptoms are: When I tried to boot for the first time the cpu and case...
If you have recently upgraded your motherboard and when you turn it on, there is no display. You could check the jumper setting of your motherboard.
Check this site for jumper settings. Download the manual. Go first to page 11 and find clear CMOS jumper. That will be number 17. Then go to page 24 for the correct jumper settings. Jumper should be on the pins 1 and 2. That's the default settings.
If the jumper is set already to 1 and 2. Clear the CMOS by putting the jumper on 2 and 3. It should be off when you are going to set the jumper. This is to make sure that the settings for your motherboard is set to its original settings.
If you are going to clear the CMOS settings, you will have turn the computer on after clearing it and then turn it off again. Put the jumper back to pins 1 and 2. Now make sure that computer is totally off. Uplugged the computer just to make sure when you are doing this.
To test also the motherboard if it is working, do not connect the other pheriperals such as network card, sound card, and other cards that is not buit-in. Also drives such as Hard Drive and CDROM drives.
Check for beep codes. Short beeps tells you that the Video card is not inserted properly. Long beeps tells you that the memory card is not in place correctly.
Just remove the Video card or Memory card and then place it back again.
Computer should be off as well when doing this.
Sep 09, 2008 | PC Desktops
Jetway S755MAX Rev: 1.0 BIOS Update
I understand what you are saying. The only course of action I see left is to e mail the company and ask them if there is a way to skip the "disabling" step in the update. If there is no way to skip the step then I see no way to update the Bios.
Apr 28, 2008 | PC Desktops
Jumper setting
Amigo !
just tell me your main board name and model.
Mar 29, 2008 | PC Desktops
Foxconn F845DA jumper settings
JP1 PIN 1-2 = On board audio disable
JP1 PIN 2-3 = On board audio enable
JP2 = Temperature Sense connector
JP3 PIN 1-2 = Normal
JP3 PIN 2-3 = Clear CMOS
1. Power off the system and unplug the chassis AC power cord.
2. Short JP3 at PIN 2-3 for a few seconds.
3. Set JP3 back to it's normal position at pin 1-2.
4. Plug the AC power cord to the chassis.
5. Power on the system and load the BIOS setup default.
Mar 25, 2008 | PC Desktops
E-Machines T1090 PC Desktop Logo
78 people viewed this question
Top E-Machines PC Desktops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you an E-Machines PC Desktop Expert? Answer questions, earn points and help others
