Old Hotpoint dial seems off but cannot find starting point
I have an old Hotpoint washing machine. Not sure which one it is. Problem started with the dial not turning, so I used presure on outter ring to turn it. Then it was slightly out of alignment so that the start was actually before the start.Now I suddenly cannot seem to find where the start is. It starts to fill with water, so I add soap to start it disolving. Then add clothes. Come back later and there is no water, the dial barely moved, but there is dried soap everywhere. Tried other positions to no avail.Just had to replace a fridge and dishwasher within the last 4 months and really cannot afford to replace this right now. Do I just need to realign the dial? If so how? I just need another 6 months out of this so I can save money for a new one.THX
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 17, 2010
My washing machine has started beeping during the wash cycle - why?
Try running the same wash cycle with no clothes in the machine, just the water.
If it does not beep you are overloading it or the load is unbalanced.
Dec 20, 2015 | Hotpoint Aqualtis AQ113F497E White 595 mm...
Hotpoint Aqualtis 2 months old dial turns without changing the display
machine is under warranty, contact Hotpoint for a service call.
Oct 15, 2012 | Hotpoint Washing Machines
F-01 error hotpoint WMD960P
Error code F01 is indicating ashort circuit motor triac.
Check connections on motor the motor plug and then control module.
Please rate my solution.
Thanks.
Nov 17, 2009 | Hotpoint Washing Machines
Hot Point Washer will not drain water from tub.
my old hitachi washing machine PAF-760P was not used for a long time.I started yesterday, it started washing but when the knob rotates and goes to drain the water,it only clicks and does not drain the water. What must be wrong with it. can you help please.
Jul 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint - door locked, won't start, please help
to open the door to get your clothes out you will need to take the top cover off and then get a screwdriver to move the latch across.
make sure the plug is off so no power! and an engineer may be required if you can't acertain the problem.
Jan 23, 2009 | Hotpoint Aquarius WD63 Front Load...
Hot point wmlt80, dail clicking and turning, cycle wont start,
Yes, I work for GE what you need to do is to resent the appliance. Something should had happened with the computer of the washer. Just unplugged the machine for 40 seconds. You can unplugged or turn off the circuit breaker for 40 second and plugged back in. Select a normal cycle and let it run.
Jan 15, 2009 | Hotpoint WMTL80 Top Load Washer
Child lock
Try turning the dial back to off, and then try it again.
Make sure the door is shut properly.
Don't interrupt a prog once it has started., if you do , it will start to do funny things.
Nov 20, 2008 | Hotpoint VBSR3100D Top Load Washer
Old Hotpoint won't spin tho can hear a hum (when turn dial to spin cycle)
clarification:
the machine neither spins nor agitates on wash cycle and apparently as a result does not drain
jungleman
Jul 09, 2008 | Hotpoint Washing Machines
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
