The fuse from the power supply is fine, and there is 120VRMS reaching the main power supply board. The relay (Tyco SDT-S-106LMR) will click on and then off immediately whenever I hit the power button. Any suggestions on next steps?
I finally figured this out after searching everywhere online and seeing people in similar situations but no solutions. I was getting 2 audible relay clicks but no power to the surround sound unit. After some experimenting this is what worked for me:
Remove all wires to the unit including the ac power cord, plug in all the cables you need THEN the power cable after. In my case I had a Panasonic sa-pt770, I plugged in the speakers to the respective colors, then my HDMI, then the power cable.
You have a problem with the power supply or audio amp section. Most likely shorted audio output transistors.
