Question about Yahoo Messenger
I'm recieving a messege , that says my version of yahoo is going to end after augest 15th, i have dial up, and tryed to update to yahoo messenger 9.0, but my computer wont completely install it do u provide an install disk , or know how i might be able to upate my pc?
    President:
  • 828 Answers
Actually yahoo messenger are not expering there software, for me that is spammer of worm trojan handle with you YM... at least download the new YM software from yahoo site....
Posted on Jun 16, 2009
I cannot read the messeges i send or i receive. i type my messeges, press send. the messeges go to the person i'm sending them to but i cannot read them. also i cannot read the messeges sent to me.
The first thing to check is to make sure you have scripting enabled in Internet Explorer. Internet Explorer is integrated into Yahoo Messenger so things that go wrong with IE can affect Yahoo Messenger. Here is the yahoo help page about that: http://help.yahoo.com/l/us/yahoo/messeng...
2) In the Start Menu click on Run. Type, without the quotes, "regsvr32 jscript.dll" and then click OK. Next, repeat the process but this time type in the Run box "regsvr32 vbscript.dll" and click OK. Please note, if you are using Windows Vista temporarily disable the User Account Control (UAC). You can easily turn it back on. On the Control Panel (Category View) choose User Accounts and Family Safety, next choose User Accounts, and then click Turn User Account Control on or off.
3) If the above does not fix your problem and you are using Windows XP, you can update your Windows Script to version 5.7. In my experience helping others, this is the step that has helped the most people. Exit all browser windows and chat programs including Yahoo Messenger before installing. run registry cleaner reginout cleaner to easily fix it
Jan 31, 2011 | Yahoo Messenger
Hi i am using yahoo messenger 10.00..i try to cam with my friend .. it always says waiting for approvel..even tho he has invited me to look.. but late at night it works fine.. is that a yahoo server ...
The problem may be at any end (Your, your friend and Yahoo server)
You said it got worked after sometimes, so the issue might be on Yahoo server update...
Thanks,
Satheesh
Jan 21, 2011 | Yahoo Messenger
When typing messeges,it appears on my box messege.but,when sending it to a friend it wont appear on my friends screen box messeging..
Does this happen just with your friend only? If yes, then his or her Yahoo!Messenger is infected with a trojan. This is a common problem with Yahoo Messenger users. Advice your friend to uninstall the current program from his or her computer and download and install the latest version from http://messenger.yahoo.com.
Please let me know if this helps. Thank you for using FixYa. Merry Christmas.
Dec 25, 2010 | Yahoo Messenger
Can not type my messege
Do you type your message and it appears blank? If yes, you need to update your Yahoo! Messenger to the recent version to fix this problem as this might be caused by a virus which infected your Yahoo! Messenger. It is also advisable to scan to clean your computer.
Dec 02, 2009 | Yahoo Messenger
Incorrect command line parameter?
i had the problem in installation of yahoo messenger it gives the messege that in correct command linepatametrer problem. just go to start control panet addremove programme and uninstall the yahoo with his all features. then go to yahoo and find the 7 or 7.5 version and download and install it. it will work BUT it will gives you the messege that u r using the older version go to this webside and down the latest version of yahoo messenger. go and find the 8.1.0.421 and download it.
alter that when u installing it it will computer will gives you the messege that u allresdy install the latest version if u r installing this one go and unistall the other. go to add remove programme and uninstall that version and reinstall the latest 8.1.0.421. when it done. give it ur id and password and make fun......
Oct 12, 2009 | Yahoo Messenger
Yahoo messeger cannot sign network encountered a coonection problem
May be u using any kind of proxy...to check it open IE ...click Tools>Internet options> Connections> Lan settings > Unchecked the Box written for [Use a proxy server for you LAN(This setting will not apply to Dial-up or VPN setting)]
or
open Yahoo messenger click Messenger> Connection Preferences>In the Network or Internet connection >select Connect directly to the Internet> Apply > OK.....
If you still facing the connection issue ..try uninstall yahoo messenger, download and install latest version of Yahoo messenger ..if that doesn't help ...may be that is blocked by your network administrator or ISP ..contact them for solution...Good luck
Sep 18, 2009 | Yahoo Messenger
I cant open yahoo messenger.it say 'there was a problem singing into yahoo messenger.please try again a little bit later'
This is because your internet connection is not constant..
Check your internet connections...
If that doesnt solve...Select..PROXY in yahoo messenger settings..
This should help you..
Jun 16, 2009 | Yahoo Messenger
I have problems with sending my messeges to people in text chat
yes i think you have some settings in yahoo changed.
so lets check that first
click on messenger (in the upper part of yahoo messenger)
click on preferences
from there click on ignore list (in the left pane).
make sure that ignore only the people below: is checked.
now hit ok
so if that is the problem now we fixed it but if it is not then you have two things to do
update internet explorer to the next version. if issue not solved then reinstall yahoo messenger and update it to YM 9.0.
that should be it.
dont forget to rate my answer
cheers
Nov 13, 2008 | Yahoo Messenger
There was a problem signing into yahoo messenger please try again a little bit later
throw your laptop to the bathtub with water and let it dry for 5 minutes and make sure that you plug it right away then turn it on.
Nov 03, 2008 | Yahoo YHT-630 System
Yahoo Messenger Logo
29 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
