Question about PSC Duet RS-232 Handheld Barcode Scanner
Bar code reader cannot be recognized by the computer
The PSC duet bar code reader cannot be recognized by the computer although other readers like Voyager bar code reader are ben recognized by the same computer
    Sergeant:
  • 361 Answers
I think it is a softwere problem .once a time you reinstal same bar code reader driver, thanks
Posted on Jun 16, 2009
I have Royal alpha 600/601SC Cash register with PS-700e bar code reader.I purchased one PS-700P bar code reader for that after the original got damaged. But I have problems with this unit. it does not
the clue is in what youve typed
you used to use a 700E type
you replaced with a 700P type
perhaps look for the 700E type that matches the older type you have
i would assume the last letter is the series ident so the one you replace it will it newer
perhaps doesnt communicate in the same exact way
Nov 30, 2014 | Royal Alpha Retail Supplies
Tip
How do I troubleshoot a Symbol Barcode Scanner?
<p>Barcode Scanners Symbol read and translates the barcodes on merchandise. The scanner translates the bar code symbols on the label says the price of the item and merchandising information. Traders use the symbol bar code scanner to identify their merchandise. A programming error in reader bar code symbol will cause confusion and may lead to loss of money. Troubleshooting barcode scanner symbol allows you to identify bugs and find solutions to errors. <br /> <p><br /> <p>1. Remove the installed fonts from the reader bar code symbol. The sources of such capacity to disrupt the functioning of your bar code scanner. Press the "Menu" button on the scanner bed and press the "Select" option when the source is highlighted. Press the Delete button to remove the sources of the sample. <br /> <p><br /> <p>2. Close the bar code scanner Symbol with a source of energy. The scanner has a power cord can plug into an outlet. If the scanner runs on batteries, the battery is fully charged before using the scanner. <br /> <p><br /> <p>3. Move the scanner closer to the bar. The symbol bar code scanner cannot calibrate the bar if you wrong position. Place the scanner directly over the bar and wait for the scanner to read and transmit the code. <br /> <p><br /> <p>4. Wait until the bar code scanner symbol to complete the boot. The symbol bar code scanner is initialized when the USB cable is connected to the computer. Initialization requires a short period of time to complete the process. Let the bar code scanner symbol to be idle for 4-5 seconds before you first scan an object. <br />
on Jun 26, 2011 | Computers & Internet
Tip
Handheld Barcode Scanner service
Do you currently have hand-held inventory scanners?
Although you may not be familiar with Legacy's Technology Services, we may already be servicing your barcode scanners, barcode printers and even POS hardware. Many sellers of extended maintenance contracts have used Legacy for years to perform service on devices covered by their contracts.
Maybe you're looking for a specific hard to find part. Chances are I've got it!
We also carry refurbished equipment if you are in the market.
Give me a call for a quote and to discuss your current needs.
Joe Anselmo
Legacy Technology Services Inc
(630) 622-2018 ext. 418
Email: janselmo@legacyglobal.com
on Apr 13, 2009 | Zebra LS1203 Bar Code Reader - Handheld...
Explain bar codes
A bar code (often seen as a single word, barcode) is the small image of lines (bars) and spaces that is affixed to retail store items, identification cards, and postal mail to identify a particular product number, person, or location. The code uses a sequence of vertical bars and spaces to represent numbers and other symbols. A bar code symbol typically consists of five parts: a quiet zone, a start character, data characters (including an optional check character), a stop character, and another quiet zone.
A BarCode Readeris used to read the code. The reader uses a laser beam that is sensitive to the reflections from the line and space thickness and variation. The reader translates the reflected light into digital data that is transferred to a computer for immediate action or storage. Bar codes and readers are most often seen in supermarkets and retail stores, but a large number of different uses have been found for them. They are also used to take inventory in retail stores; to check out books from a library; to track manufacturing and shipping movement; to sign in on a job; to identify hospital patients; and to tabulate the results of direct mail marketing returns. Very small bar codes have been used to tag honey bees used in research. Readers may be attached to a computer (as they often are in retail store settings) or separate and portable, in which case they store the data they read until it can be fed into a computer.
There is no one standard bar code; instead, there are several different bar code standards called symbologies that serve different uses, industries, or geographic needs. Since 1973, the Uniform Product Code (UPC), regulated by the Uniform Code Council, an industry organization, has provided a standard bar code used by most retail stores. The European Article Numbering system (EAN), developed by Joe Woodland, the inventor of the first bar code system, allows for an extra pair of digits and is becoming widely used. POSTNET is the standard bar code used in the United States for ZIP codes in bulk mailing. The following table summarizes the most common bar code standards.
Mar 09, 2014 | Computers & Internet
Why does our Bar code readers not recognize new bar codes when the only difference is with the prefix number. It was changed from 11C to 12C.
Possible fualty printhead. make sure head is clean. Use Isopropyl alchol and lint free cloth to clean head(don't be too gentle). Or it could be a faulty head.
Jul 06, 2011 | SATO M84Pro Label Printer
My memory card readers light comes on but the computer doesnt reg
i hope the device is being recognized by os probably windows... if yes some times drive letter doesnt come up in explorer..try typing < next alphabet of last drive letter >: in explorer address bar.
for example if last drive is F: windows try typing G: in address bar in explorer.
Aug 07, 2009 | Electronics - Others
The duet bar code reader is not been recognized by the computer
reinstall the driver of that device and try to run it again. also check the device connections if it properly installed and the compatibility of your Operating System.
Jun 16, 2009 | PSC Duet RS-232 Handheld Barcode Scanner
PSC Duet RS-232 Handheld Barcode Scanner Logo
428 people viewed this question
Top PSC Computers & Internet Experts
Jax Planet
Jax Planet
Sardar Yasir
Sardar Yasir
Level 1 Expert
Tom Chichester
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
