Question about Statpower PW-1750 Triple Outlet 1750 Watt DC to AC Power Inverter Car Audio Amplifier
Porta wattz 1750 inverter
I have 2 of these inverters, one of them the cooling fan continues to run non-stop and will not shut off
  • 615 Answers
Turn the unit off and then disconnect the negative from the back and turn th unit back on that way the inverter will use all the charge kept inside.
Reconnect the negative and start the unit ...I did that to my unit and for fun I asked tech support for help they told me that I need to buy ne one...After I reset my unit I been using now since for over 2 years...sometime it come back one every few months if I have high voltage coming and I redo this again and it your money
Posted on Sep 08, 2009
What does ocp mean on the 3000 motomaster power inverter
Unit is overheating.
1. Check fans are running. and unit is in a cool place where air can flow freely.
2. If fans not working try using an external fan to see if the OCP error goes way.
Reduce the load on the outlets (Disconnect some stuff i possible)
Apr 04, 2014 | Eliminator MotoMaster Mobile Power...
Xantrex power inverter 1750
The 14 AWG Positive wire should be connected to one side of a 30 A relay (typical fog lamp relay available at most automotive stores). The relay's other 30 A contact should be connected to the battery positive post via a 10 AWG (up to 6 ft/2 m)
Sep 07, 2008 | Xantrex Technology Xantrex Xpower 1750...
I recently purchased a schumacher 410w inverter, while it came on right away and powered my electrical device the cooling fan never came on. Is the fan supposed to run all the time, once its connected.
I recently purchased a Schumaker 410/820 watt inverter. I immediately hooked it up to a brand new deep cell batery I had purchased just prior to receiving this inverter.
I plugged in several devices to make sure the inverter worked and to get some idea of what devices I can expect this unit to handle.
I noticed that the fan only ran when I plugged in a device that drew a certain amount of power from the unit. I also plugged in a CPAP unit to make sure the inverter would operate the unit properly, and noticed that the CPAP only drew 38 to 40 watts of power and the cooling fan on the converter never came on. When I plugged in an oscillating fan it drew around 128 watts from the converter and the cooling fan immediately came on when I turned the fan on. Based on that, I would assume that the cooling fan in the converter only runs when there is enough power being drawn through the inverter to cause the inverter to heat up enough to cause possible damage to or failure of the inverter. I haven't taken the time to find out the power draw at which the cooling fan will run. Hope this helps.
Jul 10, 2011 | Schumacher 410 Watt Power Inverter...
The fridge keeps switching on and off non stop. running it off a inverter (eva power) plugged in to 240v. i have also cleaned the fan and radiator of dust
Are you in the United States? If you are, then you are running your fridge on international power settings. United States standard for voltages is 120V, you are running at TWICE that. This is EXTREMELY unsafe and quite harmful to the fridge. Please switch your inverter to 120V.
May 17, 2011 | Evercool Computers & Internet
The fan at the back of my inverter is running continuously, can you please let me know what might be the problem and how to fix it
If you have it pushed against someting or have too many things around it, it may not be getting enough air to keep cool. That will cause fan to keep running to keep inverter cool.
May 10, 2011 | APC DC to AC power inverter - 150 Watt
14.1VDC going into inverter but no ACV coming out. Red fault light is on. Disconnected fan motor and checked with meter and shows open even on high ohm scale.Are Xantrex fan motors known to go bad?If the...
If you don't have enough current to run the inverter, even at 14.1 v, it will go into protection. Make sure the wiring is heavy enough to provide the current needed to run the inverter. There should be a label on the fan saying what vosges it needs to run. Try powering up the fan outside the inverter.
Nov 24, 2017 | Xantrex Technology Xantrex Xpower 1750...
Inverter fan kicks on after turning on a light bulb
the inverter fan just kicks on to keep the system from overheating. Its perfectly normal.
Jul 24, 2009 | RoadPro RPPI-2500W Inverter
Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
How many batteries do I need to run a coleman 1500 watt power inverter
It would depend on the load being driven by the inverter (which would determine the current drawn by the inverter), the capacity of the batteries and the shutdown voltage of the inverter.
Oct 01, 2008 | Statpower PW-1750 Triple Outlet 1750 Watt...
Screen flickers
Sounds like the issue is a problem with the motherboard. Does it get worse when the cooling fan and/or cdrom are running?
Apr 27, 2008 | Toshiba Satellite A105 Notebook
Statpower PW-1750 Triple Outlet 1750 Watt DC to AC Power Inverter Car Audio Amplifier Logo
229 people viewed this question
Top Statpower Car Audio & Video Experts
xxxxxx xxx
Are you a Statpower Car Audio and Video Expert? Answer questions, earn points and help others
