Question about Sony PlayStation 2 (PS2) Console
PS2 power ribbon Help!!!!!!
When I was cleaning my PS2 my power ribbon came of connecting the reset and eject buttons and now i cant turn my console on. how can i put the ribbon back without damaging anything and where does it go? i have a 'fat' PS2 that is 5 yrs old and the code is SCPH- 30003 R. Please help!!!
  • Anonymous Jul 28, 2008
    I have to apologize for being a novice at this but if there were a diagram it would be so much simpler. After reading the solution I still can't find where to reconnect the ribbon cable. Could someone please be very specific...what exactly should I be looking at? What is that round brown piece? Is that where I'm supposed to be connecting the ribbon? Thanks.
  • 709 Answers
Use a pair of needle nose pliers and grip the connection end of the Ribbon cable by the hard plastic piece.  Insert this cable in the second connector from the front.  The connectors are located under the right edge of the CD drive.
Posted on Oct 31, 2007
PS2 Green LED remains on, system won't turn on
have you tried holding down the reset button to turn off your console. Months before I bought my Ps2 I noticed my friends turning off their PS2's using the switch on the back. When i bought mine , months later i was invited to a friends house and noticed when he turned off his ps2 by holding the reset button down for a few seconds. After playing on their trampoline i went home and tried this reset button thing and it worked. Although i had the fat bulky ps2 this trick also works on slimline models too. This should solve your problem. The switch on the back i later found out was for when you wanted to turn off your ps2 during a thunderstorm.
Jan 26, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 disk tray wont open, power light is on, eject light is off
if the ribbon cable that goes to the lens came out its gota go back it. has a plastic tab on the top that lifts up and down to lock it in place....
If its the eject/reset button the ribbon might not be in all the way
Dec 30, 2007 | Sony PlayStation 2 (PS2) Console
I was trying to clean my PS2
Here is a video i made to help you
Nov 27, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
PS2 power ribbon
Hi Anishpp
If it came loose from the buttons, you need to remove the button holder to get to the connector. Push he ribbon into the slot on the back of the buttons.
If it came loose from the motherboard, you will have to remove the guts of the PS2 to see the connector under the cd drive right side. This is done by removing 4 screws. Two are on either side of your Controller ports. Another one is located between the fan and power block. Another is to the left of the powerblock. lift the guts from the back and pull the system out. looking at the right side, plug the reset Eject ribbon into the 2nd connector from the front. Then put it all back together carefully.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
Playstation..2
Hi Sammy,
You have a connection problem in the Reset Eject circuit.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Check to be sure the ribbon cable coming from the reset/eject cable is fully inserted in the second connector from the front.
If this is not the case, you may want to check out www.playstationclinic.com . This could be a circuit problem and may need technical knowledge to gain repair.
Oct 30, 2007 | Sony PlayStation 2 (PS2) Console
Eject/reset cable
You need to use a pair of needle nose pliers and grip the ribbon cable by the stiff plastic strip and plug it into the second connector from the front that I believe is White. These connectors are near where the Reset Eject button locates. Check out my website www.playstationclinic.com
Sep 23, 2007 | Sony PlayStation 2 (PS2) Console
Won't boot up, can't eject disk tray
buy an xbox i mod them and have absolutely no problems
Jun 01, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
437 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
