I have a WAC700/05 prod no.NW000643021109. The remote control has recently started wearing out good quality batteries in a very short time please advise. Regards CHRIS FELTON.
    Brigadier General:
  • 3,917 Answers
Hi Chris,
I am afraid but this is not at all good. The remote needs replacement and cannot be troubleshooted or any suggestion to do anything technically by opening it.
Please find the bellow mentioned link where you can get the original remote.
http://www.espares.co.uk/parts/remote-controls/philips/wacs700%2F05/p/1090/128/0/875175
Thanks for contcting Fixya
Note: Please contact dealer for replacement if within warranty.
Posted on Jun 16, 2009
Remote control transmitter is good ,the receiver not working what can i do ?
Did you recently change the transmitter/ bought a new one, changed the battery? How did the problem start? Was it sudden or did the receiver die over a period of time?
Is is possible that the receiver is not recognizing the transmitter's signal. Do you have a spare transmitter? Is the spare transmitter also not working? Please give more information.
Oct 09, 2014 | 1995 Chevrolet Caprice Classic
Remote control
first make sure your batteries are good in the remote, if the remote is really wearing out, then the purchase of another is way cheaper than trying to repair it
Mar 06, 2013 | Yamaha Audio Players & Recorders
Hi, i have this remote. it works on my tv before. but now it doesn't wprk any more. please help?
Hello, Thank You for visiting Fixya.com!
Allow US to help you with your remote issue.
Many times batteries cause this issue, over time the buttons often get stuck and cause the rmeote to jam. What this means is more then one of the Button pads might be pushed in causing the remote to JAM and not function.
You can take a phillips screw driver open up the unit and clan the button pads, you also can make sure your using good batteries as well.
Many cases with these universal remotes or, original remote the pads under the buttons get jammed or dirty. A remote generally does not just die. There are many causes. Allowing a dead battery sit over time on a remote can wear down the connections on the remote. Make sure you clean these battery connections, Make sure you flex the spring inside and make sure the battery is seated in the correct position.
You can also read my Tip on how to fix a dead remote HERE
I hope you like my idea's and tips on how to resolve your problem. We hope you found this Very Helpful today, Thank You for the oppertunity to help.
Regards
Edwy aka rulds2008
Jan 24, 2011 | Philips Magnavox REM-350 Remote Control
Nissan Altima 2000 Manual. Recently had remote starter installed and was working fine for a few days. This morning I remote started the vehicle and when I came out car was off. Try starting the car up...
the remote starter is not going to damage the starter, but if wired wrong it could damage the wiring or fuses, or run the battery down from a short.
Jun 11, 2017 | Nissan Altima Cars & Trucks
I recently bought a Logitech Harmony 900 remote on ebay. The device works great when the battery is charged. But whenever I place the remote on the cradle/charger it doesn't charge the battery. There is no...
have you tried replacing nthe batterys if so then there is a short in the charging port of the base the best way to fix this is just use good batterys as per a normal remote control
Jun 24, 2010 | Televison & Video
Get yellow band saying that there is no power. Do I need a new battery?
If you've tried charging it, and resetting the unit, then yes, its time for a replacement battery - which luckily isn't too expensive.
Here's some links for replacements...
http://www.google.com/products?hl=en&client=firefox-a&rls=org.mozilla:en-US:official&hs=lLL&q=mx-3000+battery&um=1&ie=UTF-8&ei=sHOySq3HO47ssQOMiLmeDQ&sa=X&oi=product_result_group&ct=title&resnum=1
Hope this helps! Good luck!
Sep 17, 2009 | Universal Remote Control MX-3000 LCD...
I AM UNABLE TO CHANGE CHANNELS USING RMT D175A PLEASE HELP
Is this the first time you've tried using this remote with your TV or has this problem just started?
If it's a recent problem, be sure you put FRESH BATTERIES in it. Some remotes will forget everything if the batteries are weak.
Then, try this site:
http://esupport.sony.com/perl/model-remote.pl?mdl=RMTD175A
You can enter your TV brand and it should walk you through re-programming your remote.
Jul 08, 2009 | Televison & Video
2004 sprinter 2500 fails to start and displays starting error, when this happens, usually the remote entry system using the key won't work either. Engine will not crank. wiggling the positive battery...
I know it sounds simple but I would replace both the battery cable ends with quality new ones or replace both positive and negative battery cables with the new ends attached. Hope this helps.
Jun 23, 2009 | 2007 Dodge Sprinter
I have had trouble with the volume adjustment for my alpine (TDA 7552), its old i know, so i dug out the remote control to use and it doesn't appear to be working even after a new battery. could it be a...
The remote that came with this unit does not last long and breaks down very fast. Alpine has a new equivalent replacement that you can order from a dealer that will work with this unit. For the volume control, yes they do wear out with time. Cleaning it with very high quality contact cleaner like DeOxit helps for a while but the problem comes back because the mechanical contacts simply wear out. A new volume control can still be ordered if you look hard. I think pac parts can get them. You would need a technician to open up the detachable face and unsoldered the old control and solder in the new one if you can't do it yourself. After that it works like new.
Mar 06, 2009 | Alpine TDA-7552
 Grubhead
Grubhead
