Question about Whirlpool LER5636P Electric Dryer
Drum won't turn
Smells like a snake crawled up into the motor and my son turned it on....now it hums and drum won't turn...anything special I need to worry about  before I get in there? It's unplugged.
  • Anonymous Apr 07, 2008
    Hi Drum won't turn. Foul smell. Sounds like the old belt is shot. How do I repair it?
  • 4 Answers
Unplug it and pull it away from the wall.
flat screw driver under the lid, it just pops open. next the face pulls forward and off, there might be screws inside at the top.
the drum rides on the face...once the face is away from the drum throw the new belt around the drum...you'll see a stain where the old one was riding. then put the face back on...have to lift up on the drum a little. ok around the back you can see a trap door held on by two screws ...open that. you'll see the pullies the belt needs to wrap around....put them on the pullies....put the top and back on again....plug it in and test it.
it's a good idea to vaccume out the dryer and pick up any loose change while your inside there :0)
i wish you luck...
Posted on Apr 10, 2008
  • 883 Answers
Not really, it may only be a little effort to figure out how the new belt gets wrapped onto the tensioner pulley...the broken one is surely on the floor coiled up under the dryer like a dead snake....don't worry...it's dead.
Posted on Nov 01, 2007
Dryer motor just hums, drum doesn't turn
check belt drum drive? check drum turns at all, it may be stuck.most drums turn with a belt. if it broke it is laying on the bottom of the dryer.didnt u see it??look again.
Apr 21, 2013 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
Dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Nov 01, 2009 | Dryers
When dryer is turned on , it hums but the drum doesnt turn. It smells like heating element is working, belt is on correctly but drum will not turn. Any suggestions? Thank uou
sounds like the bearing the drum rides on is bad. that will cause the breaker to trip as the motor strains to turn the drum on the bad bearing.
Sep 09, 2009 | Dryers
When we push the on button, you can hear a hum,
Sounds like the belt that turns the drum has broken. the hum sound is the motor turning. Does it still get hot in the drum? If so then you need a replacement belt ($15-$25).You can open the rear or the dryer to confirm the belt is broken. Be sure to unplug from the wall outlet to avoid electrical shock.
Aug 18, 2009 | Dryers
Sounds like the belt has been stretched and is not letting the motor turn the drum. If the motor is not turning at all then your motor is burnt out and needs ot be replaced
May 22, 2009 | Dryers
I press the start button and hear an electric humming noise and the drum does not turn.
unscrew the rear panel of the dryer,
You will most likeley find the rubber drive belt broken and wrapped around the drum or motor.
if so
Take your make and model details to your local parts dealer and pick up a new belt, for a few $
like a fan belt it installs snaked around the drum, motor, and backwards around a tensioner
May 29, 2008 | Frigidaire Dryers
Drum won't turn
if your lint screen is on top of dryer pull it out and remove the 2 screws under it. then there are 2 clips under the front edge of the top. with a putty knife you can press the clips to raise the top. after top is up look inside on the right and left top part of the front of the dryer there is a screw on each side should 1/4" or 5/16" head. remove thoughs screws and front folds forward and lifts up to be removed.
Nov 25, 2007 | Whirlpool LER2614JQ Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
93 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
