SOURCE: how i can stop change winows XP icon after software istallion
I think I experienced the same problem you're describing. After installing the NetGear USB adapter, Windows XP stopped using the "friendly" way of logging on -- where it has a nice icon for each user -- and started using the "ugly" logon. You get a username/password dialog box.
I checked with NetGear tech support, and they sent me the following steps:
1. After installing the new driver/utility for WG111v2, click Start --
Run and type regedit.
2. When the registry editor opens browse to
HKEY_LOCAL_MACHINE/Software
/Microsoft/Windows NT/Current Version/WINLOGON.
3. Delete the key named GINAdll.
4. Afterward you may want to go back into the control panel and check
the 'change the way users log on or off' and make sure the welcome
screen and fast user switching are both checked.
They also included the common sense caution that you should not edit your registry unless you know what you're doing. You can screw up your computer by improperly editing your registry. However, the steps are easy enough to follow that you should be safe if you exercise caution.
I would add that this didn't fully solve my problem. Although things work fairly well in most cases, when I wake up my machine after it has gone to sleep (due to a period of inactivity), the screen is messed up. Instead of giving me the normal logon screen, I get a messed up version of my desktop, and I am not able to log on. I have to turn off the computer's power and restart it.
To work around this problem, I try to always shut down completely when I log off instead of allowing the machine to go to sleep.
SOURCE: NetGear WG111 802.11g/b Wireless Adapter
After a small amount of trouble, I have configured my Win 98 laptop to use
Netgear WG111v2 wireless modem to connect to my wireless router. I used
the driver from the CD that came with the modem, following the instructions and
got to the point, after rebooting a couple of times, where I was connected to the
router, but could not reach another computer on my network (or the outside world).
I double-clicked on the wireless model icon in the system tray and noticed that,
on the NetGear SMART WIZARD panel, the WEP key was set to use the
"Create from passphrase" option, even though I supplied the already generated key (the
hex numbers) during installation of the modem. (The modem was using the key
as a passphrase to create another key.)
To fix this, on the SMART WIZARD panel, I
selected the "Enter key manually" option and, er, entered the hex key (the one
the router/access point uses for security) manually.
I hit "Apply" on the Wizard and, lo and behold, I was pinging the rest of my network.
I rebooted one more time (I had some leftover bad settings in my "Network Connection"
TCP/IP entry for the WG111 connection; I reset them before the reboot
to allow my network to automatically assign an address) and I was then able
to view my favorite site (bythestadium) from my favorite browser (firefox)
SOURCE: NETGEAR WRN 2000 - WG111 keeps scanning
i try to dowload the driver for a wireless usb adapter wg111t only one i see his detective one
SOURCE: Netgear WG111 USB Adapter won't work with service pack3 installed
http://kbserver.netgear.com/release_notes/D102534.asp
Reinstall the driver to the WG111 (after SP3 is installed).
SOURCE: no drivers
You can download the MAC drivers from the link below:
http://kb.netgear.com/app/answers/detail/a_id/2640
Rate it, if it helps.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
