Question about Sherwood SR1 Regulator
I have a sherwood magnum 2en stage that is free flowing i have replaced the diaphram, when I put air to it the free flow was comine from the arm that the diaphram releases to allow the air to flow. What do I need to do to correct this problem? (my biggest problem is I am in progresso Mexico Dive shops are hard to find and the few that are here have no ideal or parts to fix one.) Thank you, Dr. Sandy Tomaselli.
    Problem Solver:
  • 15 Answers
Check your down stream valve in your first stage. this may be stuck or the spring may be out.
Posted on Jun 16, 2009
Sherwood regulator is free flowing
Needs a seal rebuild kit.... They are simple to do, open the regulator up first and check that there isn't any salt or dirt inside
Feb 12, 2018 | Sherwood Scuba Diving & Snorkeling
Free flowing regulator
If free flow from the moment the unit is pressurized it could be the 1st stage intermediate pressure (IP) is too high or the second stage valve seat is missing, set screw is too loose, seat is damaged or has debris on it. If the free flow gradually increases under pressure it usually indicates a damaged 1st stage valve seat. A trained Mares Tech with the correct tools and genuine parts would be the best solution.
Aug 19, 2011 | Mares Rebel 12 Regulator
The regulator is free flowing the opupus is also free flowing . They are Magnum blizzard by sherwood
Your regulator requires servicing as this problem could be caused by either excessive pressure in the LP line to your Reg or the valve in the reg has become defective.
Jul 23, 2010 | Sherwood SR1 Regulator
96 blade fuel tank starvation?
The petcock has a safety in it that only allows fuel to flow when there is vaccuum applied to it. There is a second hose beside fuel hose that goes to diaphram in petcock. If the hose collapses or the diaphram ruptures then fuel wont flow. If you pull the hose off the back of the diaphram and see fuel then the diaphram is definitely shot. When you take the tank off fuel shouldn't flow. If you apply vaccuum to the port on the back of the petcock it should begin to flow. If not then petcock is bad. If it does check hose from engine to petcock.
Mar 03, 2010 | 1998 Honda CBR 900 RR Fireblade
I have an unmarked first stage reg. thats leaking air through the back side through the two small holes
Depending on the model, some regulators (such as Sherwood) always leak a very small stream of fine bubbles as part of the depth compensating mechanism. By this, the regulator adjusts the air flow from the first stage to compensate for increased depth.
As a regulator technician, I would have to see the first stage to make any educated comment or recommendation.
Feb 20, 2010 | Dacor Scuba Diving & Snorkeling
Softner model hi flo 2 water volume about half
The flow packs are not opening properly. There may a restriction in the lines feeding the flow packs or the springs/ diaphrams may be bad. I suggest replacing both flow packs and making sure all lines feeding flow packs are free of oxidized iron and debris.
RJ
Jul 01, 2009 | Culligan Sediment Water Filter
Cressi sub ellipse titanium reg is free flowing
Hi. I would suggest having the internal o-rings checked. One of them could be worn, allowing the air to escape. Or put it into your local dive shop for a service.
Apr 06, 2009 | RTO Cressi-Sub Ellipse Titanium/MC7...
Old style sherwood blizzard regulator problem
The front of the regulator should twist off with a little effort then exposing the purge diaphram, check your dry cracking and deteireation, you shoud be able to dismantle the reg and assmeble easily, and when you do get it open lube the piston and diaphram with silicone grease, but not the side you breath from just the mechnical side.
Jan 31, 2009 | Sherwood SR1 Regulator
Sherwood SR1 Regulator Logo
268 people viewed this question
Top Sherwood Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a Sherwood Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
