Question about Frigidaire FMV157GM Microwave Oven
My microwave is not heating ... everything is normal.
My microwave oven is not heating from past 2days
GE microwave oven .. light & sound are the same, is there any solution or else do i need to buy another1. i haved purchsed this oven last aug only.
  • 6,784 Answers
Ok, the heating device(magnetron) is malfunctioning. it is damaged. this part will cost $133.00 and, you will need to replace this failed component asap if possible.
Posted on Jun 16, 2009
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
Does not heat everything else works ge microwave oven JNM1851SMSS
It will be one of three things, magnetron, "heats food" high voltage diode,"sometimes cracks" or the high voltage capacitor, "usually shorts"
Mar 23, 2012 | General Electric JNM1851 1100 Watts...
Power on, everything sounds & looks normal but not heating food. When I hit power level option it does not say high, medium or low any longer.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Oct 03, 2010 | GE JVM1850 1000 Watts Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Microwave runs but food does not heat
If everything appears to work as normal but does not heat, then the magnetron will be faulty. This is the device which cooks the food, however this can be an expensive part to replace & may not be economical to fix.
Sep 23, 2009 | General Electric Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
EVERYTHING WORKS NO NOSIES SOUNDS LIKE IT IS WORKING WILL NOT HEA
could be the power fuse inside the microwave, you have to remove the casing to access these.large power fuse would seem to be the problem, this is normally 10 amps but could be 13 amp. there is also a control fuse that control the power relays
if this is blown the relays could be at fault
Feb 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Frigidaire FMV157GM Microwave Oven Logo
282 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
