Question about Kenmore 62802 Electric Dryer
No heat in my dryer
Kennmore dryers, starts, goes for a while with no heat, then, shuts off and all lights starts blinking
  • Anonymous Mar 31, 2014
    Dryer lights start blinking then shuts off
  • 547 Answers
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Posted on Jun 19, 2009
Turns on, no heat, stopas after about 5 mins and all lights start blinking.
Good Afternoon Amanda,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is not heating as well as only running about 5-7 minutes of the cycle before shutting off. There are a couple things to check.
    1)The gas supply valve is not open. Check to make sure that the gas valve is open.
    2)The dryer does not have enough air supply to support the burner flame. Check with your local gas company to make sure that your dryer is installed correctly.
    3)There is a possibility that your LP gas supply tank is empty or there has been a utility interruption of natural gas. Try refilling or replacing the tank.
    If you are still having trouble with your dryer, I suggest giving it a hard reset, by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored, start any cycle. If you are still noticing that there is no heat and it stops 5-7 minutes into the cycle, I suggest contacting your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
May 14, 2014 | Frigidaire FAQE7001LW Dryer
I smell gas when my gas dryer is not on and the pilot light is not lit prior to turning on; it is a 1997 series 70 kennmore
There is a leak in the gas line supplying the dryer. This is DANGEROUS and should be repaired.
S for the pilot light, is it continuously on or is there an igniter that only heats up when you start a dryer cycle?
Sep 22, 2012 | Dryers
Kennmore dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
cghjhc
Feb 16, 2010 | Kenmore 73952 Gas Dryer
Need wiring diagram for switch on door and light kennmore dryer
doesn't matter what side the wires go on the door switch,as for the light,one of the wires has a plastic cover on it,that goes on top and the other wire plugs onto the post closest to the bulkhead,next time send model number,hope this helps you
Jan 21, 2010 | Kenmore 63942 Dryer
Dryer shuts off right after started
You don't mention the model or make of dryer but this problem is usually due to a small component in the machine called a thermal overload switch. This switch stops the dryer when the elements get too hot. However, it often malfunctions and turns off the dryer the moment you use heat settings. The overload switch is inexpensive and should easily be found at your local appliance dealer.
Best wishes,
Graemevm
Dec 17, 2009 | Washing Machines
My dryer shuts of during a cycle for a few minutes and then starts again, independent of the heat setting. Kennmore 11062942100
check the venting, if clogged it will trip the high limit ther and cause this issue
Nov 11, 2009 | Dryers
Dryer does not heat up
my dryer work but it does not give heat ( kennmore 70 series)
model# 10062712101
ser: 1216293
i am trying to get the manual for my dryer from kennmore
Oct 26, 2008 | Zanussi Dryers
Kennmore clothes dryer
it makes a ringing noise when it is running
Aug 07, 2008 | Dryers
Kennmore dryer
if the lint screen is on top of the dryer then you can remove the back of the dryer. look around the area where the air leaves the dryer. youll see a whit plastic part with 2 blue wires going to it. that is the thermal fuse. when the fuse goes bad the dryer wont start. if your lint screen is in the door let me know so i can anwer for that dryer.
Nov 20, 2007 | Kenmore 62872 Electric Dryer
Kenmore 62802 Electric Dryer Logo
102 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
