Question about Acer Aspire One Netbook 8.9" Notebook
Just purchased acer aspire one 150-1786 netbook
Netbook turns on but quickly shuts dows before booting windows xp
  • chandonnet Jun 16, 2009
    Yes, it starts to load windows xp, but then shuts off. I did purchase this refurbished. I am using the electric power; does the battery have to be charged first, even though I'm using electricity?
  • 157 Answers
You say you just purchased it, It must be under warranty, take it back. If its not under warranty it could be a number of things. removing and replacing the ram is the easiest thing to do. Does anything show up on the screen when you turn it on?
Posted on Jun 16, 2009
  • Caleb Judd Jun 16, 2009
    No it does not need to be charged. try it with the battery out.
    Does the screen flash blue before it shuts off?
    does it restart or power right down?
How to format aspire one netbook
This is generally how your format the hard diskand install Windows.
First you need a Windows XP or Windows Vista installation CD and the productinstallation code, which is printed on the Windows label on the bottom of yourlaptop.
Boot up with the Windows installation CD start and follow the instructions toinstall Windows.
Next Delete the existing Windows partition.
Next Create a new partition.
Next format this new partition - Format the partition in NTFS not a quickformat. This will prepare the Windows for a clean install if you want to proceed otherwise quit or turn off the computer after format has been completed.
Mar 08, 2012 | Acer Aspire One AOD255-2333 Home Netbook
My acer aspire one notebook only shows windows xp screen continuously and will not promp my log on screen
Try F8 after restarting your computer quickly..if you see windows advance options go to safe mode with networking and check if its working there...in most cases like this we have to reinstall the windows..so try the inbulit recovery or if you have the cd..insert it and then restart the computer...press f12 to get the boot sequence select cd dvd hit enter..boot with the cd..get into the windows installation wizard...follow the instructions there
Oct 01, 2011 | Acer Aspire One Netbook 8.9" Notebook
My acer netbook stuck on the windows xp screen but wont start beyond that? Had turned it off and on then got to screen: your safe mode options, or start windows normally.....yet it has not.
You most likely will have to repair windows.
If you can, connect an external CD ROM drive to you Aspire One (I'm assuming that the Aspire One dose not have a CD Drive) and boot of the Windows XP CD. Go through the options as if you were re-installing XP and then when it detects the current installation choose the repair option. THis should fix the boot up issue.
Also you can try the "System recovery" Option. You will need to go through the owner's manual to find out how, but usually you boot up the laptop and tap the "F10" or "Alt + F10" key(s) and it will take you into the system recovery options. This will wipe out all the information that was on the disk before so use as a last resort.
Please rate if this helps
Mar 14, 2011 | Acer Aspire One Netbook
I have no driver for ACER ASPIRE ONE ZG5
Hi, welcome to FixYa.
First, what is your operating system. I assume you are using either Windows XP or Windows 7.
Get the driver from here:
http://www.notebook-driver.com/acer/acer-aspire-one-netbook-windows-xp-drivers/
I hope this can help.
Mar 06, 2011 | Acer Aspire One PC Notebook
How do I set my Acer Aspire one back to factory settings
At the boot menu you must choose backup mode option instead booting into windows XP directly.
That way you'll boot into a backup mode and you can reinstall windows.
Nov 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
WIndows doesn't load ,frozen, internet connection problems
For that when you power up the computer press F1 or F2 or del or ALt+F2 key to enter in bios.
Then go to boot menu and set first boot device as your harddrive.
Also disable boot from lan in advanced menu.
Disable SATA in bios.
Then save settings and exit then check.
Let me know if you need further assistance.
Thanks for using FixYa.
May 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
I it possible to uninstal Linux OS and instal Windows XP to the Aspire One ?
Yes you can install XP on that netbook.
Now because there is no optical drive in that netbook you will need an external CD/DVD drive connected to the netbook and an XP install CD.
You can get the Windows drivers from Acer here >>>>>>>
http://gd.panam.acer.com/home/
Just look under the netbook for the correct model number, select netbook, then Acer One and click on your model to download the drivers.
Regards.
Sep 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire netbook has "system not fully installed"error message
There is no easy fix for this. It would need a registry edit to fix it and without having a CD Drive and an XP install CD to boot to, it is pretty much impossible. I would suggest you send it back.
Wish I had better news. Thanks!
Apr 06, 2009 | Acer Computer AOA150 Notebook
Acer Aspire One wont turn on
Hi there
It sounds like the hard drive is faulty and has some bad sectors on it. Take the hard drive and boot the machine to rule out any other possibilities of problems with the laptop itself, if it stays on and just says hard disk not found you know its the hard drive.
You need to have the hard drive checked for possible bad sectors and have them repaired or maybe even have to purchase a new drive.
Good luck
Jan 15, 2009 | Acer Aspire One PC Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
229 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
