Question about Dell XPS M1330 Notebook
Blank screen when the power button is switched there is no display on the screen. there is a blank screen so what is the clue
  • 555 Answers
Try to check the video card maybe it has a lost contact. try to remove it and plug it back.
Posted on Jun 16, 2009
Samsung 50 Plasma TV- No picture but sound works.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 01, 2016 | Samsung 50 in. Plasma TV
Why is screen blank?
You never said if it worked with external monitor. You also didn't say if you tried the [fn]+[Fx] key combination on the keyboard to try and switch displays.
But, if you look at the screen closely, at an extreme angle and can faintly see the graphics then that means the backlight has blown out. For the displays with LED backlighting it's usually just a wire or circuit to repair. For the screens with CCFL (fluorescent) lighting it's a simple matter of replacing the inverter board.
Mar 14, 2016 | Samsung NP300E5A 15.6 Laptop i3 2.4GHz 6GB...
Xerox workcentre 7328 showing error code 116-322
Try to Initialize the Spool Disk: NOTE: Initializing the spool disk will delete all jobs in all queues. This procedure can be used when a corrupt job has caused the printer to stop printing. This procedure can also be used to correct certain machine faults.
  1. Press the ON / OFF switch. The power switch is located on the front right side of the machine under the Control Panel.
  2. Wait until the Touch Screen goes blank (this may take several minutes).
    CAUTION: Make sure to press the correct buttons all at the same time. An incorrect button combination may delete all customized printer settings.
  3. Press and hold down the [6] button on the numeric keypad, the [Energy Saver] and the [Stop] buttons simultaneously while powering ON the machine. Continue to hold down the three buttons until the Touch Screen displays several lines, goes blank and then displays lines again.
  4. Release the buttons. The machine will continue its normal boot up procedure to initialize the spool disk.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 12, 2011 | Office Equipment & Supplies
I had know clue to what display setting i have change on my ps3 now the screen is blank HELP!!
when ps3 off hold down the power bvutton for 2 bleeps, this resets the display to the most basic and from here you can run the video settings.
Feb 28, 2010 | Sony Playstation 3 (PS3) Console
Monitor displays for about 2 seconds then screen goes blank. switching monitor of and back does same 2 seconds the blank screen. tried on 2 different computers , problem still persists any clues thanks
The problem can be caused by bad caps (bulging or leaking) in the power supply, bad inverter back light circuits, or worst case will be lamps. Look for bad caps first since it is easy to see, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Most monitors will fail after 2 years.
Feb 22, 2010 | Belinea (101705) (Gray) 17" LCD Monitor
Monitor on Compaq F500 doesn't power up.
check whether the display is coming on monitor or not through the vga port, if the display is there then its the problem of display panel, if not then the fault is in motherboard of the laptop
Sep 14, 2009 | Compaq Presario 700 470024-192 Notebook
Screen going blank
try checking your power settings by right clicking on an empty space on your desktop and choose properties. then select the screen saver tab, then clik on the power button, on the power scheme settings, select 'never' on each box then click 'apply' and 'ok'
hope this helps!
Oct 22, 2008 | Computers & Internet
Display Cannon 630 powershot
Thanks for your reply
Out of frustration I was sitting looking at the camera and thought to try all buttons and see what hapenned. On the righthand side of the camera in the bottom left position is a button marked display. Normally during live display mode, you can either switch the screen on or of by pressing this button (to conserve the batteries). If the camera is powered off and then on again, the screen automatically is in live display screen active mode again. For some reason my display remained off. When I depressed this button once after switching the camera on - voyla! The display worked again in live viewing mode. I do not know whether the screen is supposed to stay in the off mode when powered down in live display off mode even when it is switched off and then back on again or not, but the previous times I did, it was automatically on when powered up again.
So, before repairing your camera, please make sure that it is actually broken - refrain from making a fool of yourself like I did.
Thanks once again for your support
Regards - notsobroken
Feb 12, 2008 | Video Cameras
Screen and touch-pad buttons
1-Check the battery status of u r mobile , charge atleast 6 hours
2-There is problem in display.Than contact LG care center
Nov 08, 2007 | LG KG800 Cellular Phone
No responce
It might be that the screen has gone dark due to overheating (was unit in bright sunlight?). If you look carefully, the screen may still be on - but very dim. Go thru the menu until you get to display and try to reset it to a brighter state.
Apr 27, 2007 | Garmin GPSMAP 276C GPS Receiver
Dell XPS M1330 Notebook Logo
221 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
