Question about Maytag MSD2756G Side by Side Refrigerator
Ice buildup in the bottom of the feezer - Maytag MSD2756G Side by Side Refrigerator
  • 135 Answers
Plugged drain. Thaw it out and run a stiff wire through the drain. You can use a hair dryer - keep it moving and be careful not to melt the plastic! Also after ice is soft try hot water thru the drain. Catch pan below is small so you may have to empty it a couple times. Hope this helps!
Posted on Jun 16, 2009
The feezer side is making a loud noise and will not stop. it seems to still be cooling just fine on both sides. thier is no burning smell or anything. i tried dissconnecting the ice maker and that did...
From what you're describing it sounds like the freezer fan motor is causing the noise you hear. The freezer fan is the only moving part in the freezer section. I recommend replacing the freezer fan motor & fan blade together. If there is ice buildup on the back wall of the freezer then the sound is likely from the fan blade hitting the ice and you will need to defrost the unit.
Jul 31, 2011 | Frigidaire Refrigerators
There is no cold air blowing
Ck for ice buildup in back of freezer as this blocks air flow and is a very common problem . also listen for the fans . . if feezer is too warm the fan will not blow . and could be a bad defraot termonator . ,,mm feed back pls ..
Nov 08, 2010 | Admiral Refrigerators
Frost and Ice Buildup
If everything is cooling fine and the frost is not on the back wall but just the floor at the bottom then your defrost drain is stopped up. Remove the bottom basket and clean up the ice on the floor of the freezer. Look on the back wall and you will see some more ice up a littler higher at the back. This is where the drain is. Clean all the ice out from this area too using hot water or a hair dryer. Once you find the drain hole make sure you get all this ice out of it as well. You can take a screw driver once you have melted the ice and gently push it through the drain hole. Once the hole is cleared you should be able to pour hot water freely through the hole. (It is best to turn the refrigerator off while you do this)
Jul 01, 2010 | GE Profile PSS26NGS Side by Side...
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Freezer not cooling like it shoul
Q" what was the problem with icemaker . most common is freezer is too warm causing ice mker not to make much ice and some times no ice. .. try cleaning the cond coil and make sure both fans are going . if this does not help / unit may have lost some freon and need some to get it going .. ****
Jan 18, 2010 | Amana ABB1927DE Bottom Freezer...
Ice buildup in freezerator freezer section
If it is not a frost less freezer you'll have to remove perishables to another fridge/freezer; unplug and de-thaw the unit.
Nov 21, 2009 | Gladiator GAFZ21XXMK Bottom Freezer...
Slimline feezer 8504 126 15011 works intermittantly
why do you need a freezer if you only have ice
Nov 07, 2009 | Washing Machines
My feezer builds up ice at the back on the bottom
That is one of the symptoms of a failed blower fan. Typically on Frigidaire it's behind the metal shield with the thermostat knob at the back of the freezer. Go to an online parts place and look at the diagrams. To see it the fan is failed. Unplug from the wall, remove the shield, if you have an icemaker remove the two screws holding it on the wall and it's connector, then plug in the wall and either check for voltage or watch to see the fan spin.
Sep 26, 2009 | Frigidaire FRT21H8 Top Freezer...
Water on floor from freezer side when we take out the drawer in freezer bottom, ice on bottom and hole for drainage froze also. Tried putting baking soda and warm water in but not helping
sounds like the feezer is frosted up its a simple fix take all food out of it and store it some where and take the freezer out side and u can just let it sit in the sun to defrost of buy some salt and sprinkle the salt all over the ice to help defrost it after all of the ice is defrosted before u plug it back in mix a 50/50 solution of salt and water and spray the entire freezer and then plug it back it and it should be ready to use
May 17, 2009 | GE Refrigerators
Bottom of feezer building up ice and leaking
This just happened to me. take the panel off inside of freezer and you will see the evaporator fan this could be the problem. test it before placing.Also there is a thermostat in there too. A little round device that will kick the fan on when the temp is around 34. Both parts together are about 90 bucks if you get them yourself online. About 170. through a dealer.
Apr 10, 2009 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
90 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
