Question about Samsung SCX-4216F All-In-One Laser Printer
Fax machine problem
I have a problem regarding my SCX4216F unit. Whenever a page prints, whether from fax or copy, there appear two thin black lines that run longways down the center of each page. These two lines are about a centimeter apart. No one in our office can tell if this is a hardware problem a problem with transmission, etc.
Please call me at 773.929.4000x117 or e-mail at edionisio@nextpoint.com
  • 1,113 Answers
I can tell it is a Hardware problem. sounds like mark on drum unit, pull it out and inspect it, slight chance it is toner cart or fuser assy
TRE
Posted on Oct 31, 2007
Copier quality
Most fax machines would have a resolution selector to vary clarity of transmitted documents. The same would also hold true for scanning jobs. I would discount the possibility of the power supply since everything works except for the quality of the copy/fax. If the printer still works OK (quality of print out) then it is the scanner's availability to copy that is the issue. With current prices of all in one printers (fax/scanner), purchase of a new unit might be more practical not only in terms of cost but in downtime.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
A thin line also appears on the photocopy.why and what is the solution?
The page goes thro the feeder mechanism and passes over a thin strip of glass; maybe about 1/4 inch wide and runs across the fax under the cover where the paper is fed. You probably have dirt,corrector fluid or something like that on the glass this will cause the problem of a black line down the page to appear at the other end when you send a fax...and also to appear on your pages when you make a copy...open up the machine and clean the glass...cant help any more as you didnt state make or model.
Nov 04, 2010 | Office Equipment & Supplies
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
3 black smudge horizontal lines on prints
Your brother can send faxes without printing the pages try your computer just you should download the driver.
You can download the driver from this link: " http://download.cnet.com/Brother-MFC-8220-USB/3000-2118_4-65318.html ".
About the lines which appear on the print, you will have to buy a Drum unit for your Brother 575, because the drum cleaning blade has quit working and there is no other way to fix this only by putting a new drum unit.
note:
the drum unit is different from the toner cartridge, but if you search good you can find them together for lower price.
Please rate me
Jul 15, 2009 | Brother MFC-8220 Fax
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Black lines on faxes
Open up the document feeder (where you put paper to send) and look for wite-out on the thin glass.
If it's not dirty, you probably have a bad scanner unit. Uneconomical to repair.
Sep 23, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Samsung SCX-4216F All-In-One Laser Printer Logo
93 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
