Question about Acer Aspire 1640Z Notebook
Does not boot to windows .Only windows Icon apears when I boot.
I updated the intel chipset from acer website.After rebooting windows fails to load.I am using windows Xp pro.When I boot only windows XP icon appears and nothing seems to be working.Can anyone help.thank you.
  • regimane Jun 16, 2009
    Thanks for ur reply but i can't get to safe mode as well
  • Acer Master
  • 2,404 Answers
Try going into safe mode and uninstall the intel chipset and reboot and see if you can get back into windows.
Posted on Jun 16, 2009
  • Ben Wabnick
    Ben Wabnick Jun 16, 2009
    Since you can't get into windows or get into safe mode, you'll have to restore your computer back to factory defaults, did your laptop come with the recover discs.
    President:
  • 828 Answers
Reformat your system...
Need driver for windows 8.1
You need to know for what brand. Example. Windows 8.1 brand hp,dell,Sony,acer,gateway,Toshiba. You may need to go in the manufacturer website to update bios and chipset ,Intel or amd. Also, is 32 or 64 bits? Did you upgrade it? Or is original?
Here is my solution.
Web search to update your PC by brand. Then when found. Update bios and chipset for 32 or 64/bits.
Good luck. If need more help. Replay here.
Dec 27, 2015 | Cars & Trucks
Power failed during MSI P67A-C43 B3 bios update
Download the latest BIOS update from your computer manufacturer's website onto a USB flash drive. Refer to your user manual to obtain the manufacturer's website address. If the downloaded BIOS file is a zip archive, unzip the contents onto your USB flash drive. Jumper settings may need to be reconfigured on some motherboards to enter BIOS recovery mode. Most Intel-based motherboards have a jumper setting or switch near the on-board CMOS battery. The procedure for setting the jumpers will vary depending on your motherboard make and model, so refer to the motherboard documentation for specific instructions. Power on the computer and press "F2" to access the Setup Mode menu. If you are unable to access the setup menu, you will not be able to proceed with this repair. Take your computer to a repair shop, as the motherboard may need to be replaced. Use the arrow key to select "Boot Priority" or a similarly named field. Press the "Enter" key. Scroll down until "First boot priority" or "First boot drive" is selected and press "Enter." Select the USB flash drive as the first boot priority device. Press the "F10" key to save this setting and exit from the setup menu. Connect the USB flash drive to an open USB port on your computer. Then let your computer fully reboot. The USB flash drive should be detected and the BIOS should update automatically. When the update is complete, you may be prompted to restart your computer, or it may reboot automatically. If you are able to use your computer without any further problems of overheating or failure to recognize drives, your failed BIOS update has been resolved.
Apr 05, 2013 | MSI P67A-C43 B3 Desktop Motherboard -...
HOW to install windows xp on intel dh61ho motherboad
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+6+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DH61HO
In general, what you'll need to do is:
  • Turn off your computer.
  • Power on again
  • When you see the splash screen or BIOS menu (and before Windows starts to load), hit the Delete key.
This will typically either get you into a boot device menu or the BIOS settings where you should be able to select the device you want to boot from to adjust the boot order. In other words, your computer may normally try to boot first from the hard drive drive.But now you have to select to boot from the dvd drive. Save the changes, and then boot your computer again, this time without hitting any button and lay the windows disk in the dvd drive. If all goes according to plan, you should soon see a "Windows loading" message on your screen and press any key to install windows.You can follow the on-screen instructions to install Windows on your computer.
You also need to make a full format of the harddrive, and reboot again.
Look also in the manual how to setup the bios.
Here is some youtube video that shows how:
http://www.youtube.com/results?search_query=how+to+install+windows+xp&oq=HOW+to+install+windows+xp&gs_l=youtube.1.0.0l10.1637.1637.0.3243.1.1.0.0.0.0.122.122.0j1.1.0...0.0...1ac.2.LqJatFrFwa4
When the installation is done, you have to install all the driver for the mainboard.Graphic,sound,chipset etc.
Good luck
Jan 28, 2013 | Intel Desktop Board DH61HO - Classic...
After re-installation of the windows, sm bus controller driver is showing a yellow sign question mark. PC is really slow to the extent that i get scratchy sounds while playing audio and video files. Main...
try the drivers from this page:
http://www.emachines.com/support/drivers.html
select your model and operation system, download and install.
Eventually, reinstall the operating system and use drivers on this site.
Feb 18, 2011 | Computers & Internet
I have a Acer Extensa 5630, with windows xp running on it. There are two missing drivers Mobile Intel(R) 4 series Express Chipset Family and Audio Device on High Definition Audio Bus. I have already tried...
After doing the Updates from Acer it is also necessary to follow with Windows Updates as well. Windows Updates is where you will find the Audio Bus Drivers. And possibly the most current Compatible Chipset Drivers for XP. If there are no Updates available for you to Install, Then we will manually update the drivers through Device Manager if needed. Click the folllowing link for Windows Updates Website. BE SURE TO CHOOSE THE "CUSTOM" OPTION. After the scan completes and the results are listed, Look at the LEFT PANE under HARDWARE as well as SOFTWARE Results. Put a Check Mark next to any that appear in those two sections. OK?
ALSO, I have One More question to ask you. When you downloaded the Drivers from the Acer Website, did you download the files to the Desktop? If so, Prior to double clicking on the Icon to begin installing, You MUST do the following: 1) Take your mouse and right click on the icon. 2) click on Properties (at bottom) 3) after the Properties Window opens, Click on the "UNLOCK" button. 4) click APPLY & OK to close window. Do this for EACH DOWNLOAD before installing.
NOW YOU ARE READY TO DOUBLE CLICK ON THE ICON AND BEGIN INSTALLING SOFTWARE. IN FACT, MAYBE YOU SHOULD BEGIN WITH THIS FIRST, and if they still don't work, follow with the other suggestions at the top of this page.. OK? GREAT LUCK & PLEASE DON'T FORGET TO RATE MY SOLUTION.. Thank You :)
Oct 09, 2010 | Computers & Internet
Problem loading into windows 7 after updating bios
FIRST - you didn't use the bios update from ASUS?
Second - USE CORRECT HEADER FOR QUESTION
Third - This is an
Intel® Desktop Board DG31PRCorrect?
Found Different BIOS file than one you used.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2839&DwnldID=18881&lang=eng
ALSO = List of ALL BIOS Updates (quite a few)
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
BIOS you used is two years old - on page 2
Try a newer version
Apr 04, 2010 | ASUS P5LD2-VM Motherboard
Intel chipset
go into uninstall programs from control panel and click on show updates box. uninstall sp3.
May 23, 2009 | Acer TravelMate 6291-6753 Notebook
Is it possible to update Chipset drivers after swapping M/Board?
Sorry for not ignoring this but no you cannot update the chipset. Unfortunately you will have to re install windows.
Dec 31, 2008 | Acer Aspire T650 (AST650UC3601) PC Desktop
Audio doesn't work. Drivers?
"Then the PC got restarted (I'm told that's all)"
???? * grin*
Check the most obvious first. Check the audio IN jack on the back, check the power chord is plugged IN, (and on the back of the speakers too) check the master volume , then check the sound settings(one formulti media and sound and one for realtek something~) in the control panel.
Seems to me the most likely is that someone was messing with your stereo settings (loose term *s*)
If this proves fruitless...force windows to update the drivers and lead windows BY THE NOSE to the exact drivers YOU choose. (whether it likes them or not)
I am sure that these procedures will help you fixthe problem but if by some mere chance it doesnt.
Uninstall the realtek software, and remove the sound card from the control panel system list. Reboot. DO NOT let windows load the drivers ON BOOT ( hit escape repeatedly if it tries to)
and then once you are completely UP. Install it again, forcing it to take the drivers that you know are right.
reboot for good measure, especially since you have had to make so many changes.*s*
Thank you and Good luck *s*
Oct 27, 2008 | Intel 845GE Motherboard
Cannot install windows xp
sounds like a bad usb device or memory. try eliminating unnecessary things.
Nov 07, 2007 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Acer Aspire 1640Z Notebook Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
