Question about Maytag Neptune MAH5500B Front Load Washer
My Maytag front load washer model MAH500BWW doesn't drain.
My washer goes through a complete cycle and when it is suppose to drain it doesn't. There is a rubbery smell that comes from the machine and I don't hear the pump come on to drain the water out.
SOURCE: washer does not drain completely.
I'm not sure if this is the same model as our but I will let you know ours did not drain all the way and kept stopping, not completing the cycle. We found that if you take the bottom of the front of the washer panel off thre is a circular looking thing, it happens to be a trap for waste, sort of like the dryers lint catcher. Make sure you put something under it befor you loosen the cap water will come out. When we took the cap off, it was filled with gunk and we cleaned it out and the problem was solved!!!! Amazing because we tried everything , called everyone and not one person even mentioned we had a trap in the washer... It should be right in the center when you take the front lower panel off.. Good luck and let us know if it works for you..
Sincerely,
Mac077@sbcglobal.net
Posted on Jan 28, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Error COde "nd"
"nd" refers to a No Drain issue . check for rstriction in pump assy, restricted drain hose loose wire at pump, bad pump
Posted on Mar 03, 2008
I had a similar problem until it finally gave up draining altogether. I took the drain pump apart and found that a quarter was jammed in the pump after it broke a vain off. I don't know how the quarter got past the basket but this was definitely my problem.
Posted on Mar 29, 2008
Lumpy816
  • 246 Answers
SOURCE: Maytag Washer will not spin
Pull the unit forwardand lean it back about 45 degrees. You'll have to play with it a bit, but once it's far enough out, it will lean back without you having to hold it. Remove and inspect the belt(s) are they in good condition? Next, check the pulleys (wheels) underneath. Do they turn? One is for your pump, one is for your transmission and one is for the motor. (in case one doesn't turn, you'll know what portion needs to be worked on). Also check the track on your pulley the belt sits in. Is it dammaged or worn?
Posted on Jun 16, 2008
SOURCE: ariston awd121 washer will not complete wash cycle
I'm also having the same problem. I hate this machine!
Posted on Sep 22, 2008
Wil not completly drain no code
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Maytag NFW7200TW Front Load Washer
Spin cycle (7min) starts, spin perfectly, try to let water go (doesn't work) then reset back to 7min... ND code does appear but not all the time
ND error code means no drain check the pump filter check the pump and check the drain line that goes from the oulet port coming out of the outter tub to the pump and also check the drain hose leaving the pump that goes out of your washer as well. If you have any further questions message me back I await your rely
Thank you,
Rick
Oct 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag model LAT8006AAE won't complete spinning water out. Stops and won't advance any farther. It does this on both long and short cycles.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 18, 2011 | Maytag Washing Machines
May maytag tl fav6800aww goes to slow spin then before it goes to high speed spin the water does not drain. please help me to open top and front panel to see if there is a drain plug
Google "washer repair forum" and choose any of the Appliance Repair forums that you hit. Post your model number and I will help you out. If you don't have the FAV6800A/FAV9800A Service Manual I can help you with that at a true DIY Appliance Repair Forum.
I will help you get the FAV6800A/FAV9800A Service manual and we will work on the slow spin issue.
There is no drain plug we need to resolve the the machine not completing the wash cycle........Rich
Nov 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Washer never stops running, goes from 1 cycle to the next
The timer is not stopping the agitate mode. And the timer is suppose to have its own off setting at the end of cycles. Suspect pretty strongly that the timer is at fault. Cant say for sure without looking at a wire diagram and eliminating any other controls.
If this helps you please rate me as high as possible.
If it doesn't help you please rediscribe your problem in more detail to help me understand, post back and I will follow up.
Mar 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
Mar 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Feb 28, 2009 | Maytag MAH20PD Front Load Washer
Washer won't drain
Check your drain and filter on the washer. It is most likely clogged with debris.
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
236 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
