Question about Troy ExtendNet SX Print Server
ExtendNet Pocket Printer ESI-2841 - Link Light fails to come on.
I have three ESI2841 Pocket Printers and we can not get the Link light to
come on.  We have checked and double checked the hub and the LAN cables.  The disable option turns the Link status light on and off as selected.
Did you connect it hrough a swirch with a network cable, or to a pc with a crossover? It is not a smart adapter, can't do midi or tx.
Posted on Jun 21, 2008
What to do if three light buttons are flashing?
It would have been more easier, if you would have mentioned the printer make and model number. To help you resolve the issue, please follow the instructions given below:
Do a Printer Self Test print,
Most printers have a way of printing a test page. A printer test page allows you to determine if the printer is working. If you are not sure if your printer has this feature or how to perform it, refer to the printer manual or visit the printer manufacturer's website.
If issue persists, please find the link below and follow the step-by-step instructions:
Apr 05, 2016 | Office Equipment & Supplies
Reset ESI 2833 until red light turned green. Network Printer still not responding
Check the IP Address of the 2833. I believe there is a gray button you can depress to print out a configuration sheet. If the wireless modem was also your router, you may have a different IP address range and will need to set the 2833 accordingly.
Sep 03, 2013 | Extended Systems Pocket Print Server
Does ExtentNet 100x support Zebra printer language ZPL2?
It doesn't support it directly, but it shouldn't prevent it from working. However it might be sending extraneous PJL commands between print jobs (example @PJL -12345X) which could mess up a label. ZPL is basically ASCII, the ExtendNet shouldn't prevent ASCII delivery.
Feb 14, 2011 | Extended Systems ExtendNet 100X Print...
I have an extendnet sx ESI-2811 Print Server. It doesn't work and I can't ping it when directly connected to my laptop via ethernet cable. It must be broken. Any ideas?
Use a crossover cable to connect laptop directly. Does your print server have a static IP address and do you know what it is? If yes, set a static IP on your laptop that is in the same subnet and with the same mask, then you should be able to ping it. If the print server is obtaining an IP by DHCP, you will have to set up and run a DHCP server on the laptop (or connect it with a straight-thru cable to an existing router that offers this service).
Jun 21, 2010 | Computers & Internet
I have a Troy 2900a or Extendnet 100x print server. It has three printer ports and I need to be able to configure the other two ports to print on the network. I've logged into the print server and looked...
Thanks for using FixYa. You’ll need to share the printers. If the printers are different than install all the printer drivers. For detailed description to configure the other two ports to print on the network please follow the step-by-step procedure on the link---
Print on network
Please do accept the solution if the issue is resolved or post a comment for further assistance.
May 06, 2010 | Troy ExtendNet 100x Print Server
Printer error
If all the three lights are on, then the issue is with the board (formatter board to be precise). Press the green button to check if there is a difference in the light pattern, the first light pattern is called primary light and after pressing the green button, the format changes to secondary light pattern, please find below the link to check the different light pattern for primary and secondary light pattern.
HP LaserJet 1160 and 1320 Series Printers - Printer Light Patterns (Error Messages)
May 16, 2009 | HP LaserJet 1320n Printer
ESI-2831 Drivers missing
Here is a Manual. As for the drivers came up short on them sry.
Apr 19, 2007 | Extended Systems Pocket Print Server
User: admin Password: extendnet
Feb 21, 2007 | Extended Systems PocketPro Print Server
Troy ExtendNet SX Print Server Logo
551 people viewed this question
Top Troy Computers & Internet Experts
David Payne
David Payne
Are you a Troy Computer and Internet Expert? Answer questions, earn points and help others
