Wharfedale WDM1381 when loading disc a constant clicking sound is made whilst spinning and disc does not load.Loading is written on screen.
  • 52 Answers
The disk is probably corrupted. Try it on an another DVD player. If it doesn't work on anaother DVD player spray some furniture polish on the DVD, leave for 30secs / 1Min and rub down with a lint free cloth if the DVD ids not too badly corrupted you may get it to work by doing this.
If the DVD Player is the problem get a lens cleaner, £10 quid. insert the cleaner and follow the instructions.
Hope thats a help.
Hughie.
Posted on Jun 16, 2009
Is there an easy fix when the dvd keeps spinning and screen says loading but does not play?
You have to clean the dirt off the laser lens inside as it cant see the codes on the disc.Use a cleaning disc first or it will have to come apart to clean.
Dec 06, 2013 | RCA 9" Lcd Portable Widescreen Dvd Player...
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
The cd player do not spin it comes on then go off
Hello
The sled motor of your player is not working. This is the motor that spins the disc inside as soon as it has been loaded. But to spin disc, the disc must be loaded properly into the loading mechanism. Just check the loading belt that attached with loading motor and loading gear set for any loose, which may cause improper disc loading. Replace it first. If it does not help you, check the voltage at the seled motor terminals. There must be a voltage [4.5VDC approx:]. If the voltage is there and still the sled motor does nor work, replace it. If voltage is not there, the fault is with the loading IC which is soldered to the main board of the device. OK>
Jan 05, 2012 | Lenoxx Electronics Audio Players &...
Dvd says just loading and after a while - no disc
Quite often it's just a case of cleaning the laser. You should be able to buy a CD / DVD cleaning disc.
Hope this helps.
Dec 23, 2009 | Wharfedale Televison & Video
Wharfedale DVD- 265 saying invalid disc
Check and see if there is dust or dirt or something on the lens. Dirt, grease and fingerprints will cause a DVD player to have read errors.
If it a new player, or under warranty, get it replaced. It sounds like it is failing.
Hope that helped.
Jan 01, 2009 | Wharfedale Televison & Video
Disc gets stuck on "loading"
laser lens may need cleaned or realind! claen and try again
Dec 12, 2008 | Televison & Video
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
I have a trutech dvd player modelT600-D. Loading only..
It clicks and keeps loading after a while it says"wrong disc," I just have it for a few months and it acted like this. I checked inside, it seems like everything is correct but it just clicks and never spins. or it says error disc... i just bought this GRRRRRR!!!!!!!
Dec 09, 2007 | TruTech TT320
DVD player problem
you allneed to make sure the disc is spinning in the player you should hear it whirr as ut builds speed listen closely to it and keep a hand on it to feel when the disk quits if it starts. its supposed to spin v ery fast do you think you could tell by the sound of it if its spinning fast. some times they make a clicking noise because the drive mounts have slid down in the case and allows the disk to rub or tap the case. please let me know what you find out. this is for all three problems. let me know the results so i can further advise you.
Nov 26, 2007 | Cyberhome CH-DVD 300 DVD Player
Keeps saying loading but never shows picture
take your set to tech the lens need to be adjust or the strip is getting in the way.
Feb 19, 2007 | Sungale PD708 Portable DVD Player with...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
