Question about Garmin nuvi 255W GPS Receiver
Entered wrong num. in add. now cant erase it.
Entered wrong num. in home add. Now cant erase it.
  • 14 Answers
Select TOOLS then Data then delete home address
Posted on Jun 16, 2009
How do i set home in my nuvi 2505 when the wrong address was added at first
To change the home address on the Nuvi, select Where To? on the left side of the main screen. Then choose Saved > Home and then press i > Edit . After you make the needed changes, press Done. (To edit some Saved items, you have to press Menu (the icon with the horizontal lines) after pressing the i button to see the Edit option.)
The manuals for the Nuvi 2595 LMT and the 2505 are available here: http://support.garmin.com/support/manuals/manuals.htm?partNo=010-01002-01&language=en&country=US .
I hope this helps.
Sep 29, 2012 | Garmin nuvi GPS
My htc dream phone is locked. the wrong pin was entered several times so it reads 'sim card is PUK locked'
To perform a hard reset (this will erase all data)
1. Turn the HTC off. If it's frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle. Now to wipe the device clean:
3. Press Alt+L. 4. Press Alt+W for a factory reset. 5. Press the Home and Back keys again for about 25 seconds. The device should then reset again and the hard reset is complete.
Oct 18, 2010 | Cell Phones
Cant unlock ipod
if you forgot you combination code then you have to restore your ipod to factory setting. y Or you can randomly try to unlock it , there are only 9,999 possibilities, If your 'friend' can remember any of the numbers it decreases the number of attempts that you'll have to make. To restore Connect to the computer that you sync with and hit restore from iTunes. Important note :-when you reset your ipod, it will erase all data from your iPod. You'll need to add your song and data again.
May 22, 2009 | Computers & Internet
Microsoft office home and student Product Key
Check for the mutliple verison from programs and features if you are using windows vista , add and remove programs if you are using windows xp
Apr 20, 2009 | Microsoft Office Home and Student 2007...
I cant sign in yahoo mail...
probably you are typing wrong password. check caps lock and also num lock if your password contains numerals
Feb 07, 2009 | Yahoo YHT-630 System
Pin bloked
you have entered the pin code wrong 3 times now you are required to enter a puk code to reset the pin code.
The puk code is sim card spesific it comes with the sim card when you get it or you can get it by calling your phone service provider of the sim card to get the puk code.
if you have entered the puk code wrong too many times you will make the sim card useless and you will have to contact your phone service provider for a new sim card, it will probably cost.
Sep 30, 2008 | Sony Ericsson W300 Cellular Phone
Occurrence of a number
the forloop is designed to add or suptract the numbers in the prase. if your outcome is supposed to be that the number is supposed to count the times you enter the number then you are correct. but if not try using a if statement. ex.
for (i=0; i <= num; i++)
cout << i;
if (num == 5)
cout << num;
else
cout << " number entered is wrong";
Sep 05, 2008 | Computers & Internet
Wireless Home Network with 2wire modem
hi dear
try this
  1. Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their web site or when you purchase access you will be provided the information.
  2. Ensure you have a firewall program installed and running. This will protect your data.
  3. Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
  4. Click on the Wifi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab.
  6. The next window will show the type of networking card installed. Click on the Wireless Networks tab.
  8. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
    • If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
    • If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if that is required.
  9. In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message will pop up and you will need to re-enter the key.
  11. Next go to Start - and where it says Connect To click on that and you should see choices like in the graphic below. Click on Wireless Network Connection and it should work.
There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
oke post in me back
i hope this usefull for you
thanks
cropp
Jun 18, 2008 | Computers & Internet
C++
#include<iostream.h>
#include<conio.h>
#include<process.h>
void main()
int num;
cout<<"\nEnter a number:";
cin>>num;
for(int i=2;i<num;i++)
if(num%2==0)
cout<<"\nThe number you have entered is not a prime number";
exit(0);
cout<<"\nThe number you have entered is a prime number";
return 0;
PLEASE DONT FORGET TO RATE
THANKS ANS REGARDS
Jun 09, 2008 | Computers & Internet
Samsung SGH-x820 PUK
My sgh X830 is askin moi fr a puk code i changed the code and cant remember it wat is the puk num
Aug 07, 2007 | Samsung SGH-X830 Cellular Phone
Garmin nuvi 255W GPS Receiver Logo
78 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
