Question about Mtd 22" Yard Machine Push Mower
The rope broke on my lawn mower and I am trying to rewind the spring, but was advised to buy a complete starter assembly, I need to know how much one is and where can I get one. I bought my lawn mower from Home Depot. Can I get one there?
  • 376 Answers
If your rope broke, there was no reason to take the spring out. The rope can be replaced just by taking the rewind housing off, turning pulley to get rest of old rope out, wind the pulley (and spring) the direction the rope would be pull it when starting. Then , when it's wound tight, back off to align the holes in pulley and cover. Hold it there, stick about an 8' piece of rope from the outside through the pulley and tie a knot. Hold the rope and let the spring pull the rope back into the starter. an tie handle back. Take your housing, and spring to a shop. They can re-install the spring and put on a rope a heck of a lot cheaper that buying that whole assembly.
Posted on Jun 16, 2009
  • 4 Answers
Rewind the spring until it's tight, then loosen one turn. Insert new rope and knot it. DONE.
How do i rewind the recoil spring on my craftsman lawn mower?
Normally these small engines use a clock spring to retract the rope.
Remove the cover on the top and you should find the spring either broken or the tab where the spring end has broken off or jumped out of the mount.
You will need to pre-load the spring with enough tension to retract the rope.
Remove the pull handle from the rope, load the spring and then wrap the rope around the pully holding the pully and spring in the loaded position. place the end of the rope through the hole and tie up the handle. The rope should pull and retract without being installed on the engine.
Best explained here...
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jun 27, 2014 | Mtd 22" Yard Machine Push Mower
Husky power washer 2600 Tried fixing starter
I'll send you a link to a great video of how to recoil a starter spring, so you wont lose and fingers or eyes. :)
Aug 01, 2013 | Garden
Pull start assembly came apart
I assume you have a lawn mower & posted the
question in the wrong place
Need to go to power equipment store with the
top motor cover & rewind assy & buy a new one
Jun 20, 2012 | Cars & Trucks
Starter rope won't retract
You have to wind the spring as tight as you can before you put the rope on. Then allow the spring to unwind, pulling the rope onto the spool. Be very careful when you take it apart. Good luck...Lee
May 29, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Recently, the rope recoil mechanism on my lawnboy mower would not recoil completely or not at all. I removed the complete recoil assembly and the rope in order to rewind the coil, which appeared to be...
Im sorry but it sounds like the spring has broken. So I am not that familiar with Lawnboy but some rewinder are not serviceable and the whole housing has to be replaced .
Oct 22, 2009 | Garden
HOW DO I GET TENSION BACK ON THE STARTER ROPE?
Try giving a few light tuggs and hopefully the spring will recoil itself. If not, you probably spung the spring and you will need to take apart the recoil assembly to get it working again. BE CAREFUL, springs have a tendancy to just 'jump' out and completely uncoil themselves and then you will have a headache for sure. Also, try reaching under the deck (hopefully the motor isn't running :P ) and turn it counter clockwise while someome one tugs at the rope. Many times it will engage itself and rewind just fine. Let me know what happens
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Sep 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Jun 07, 2009 | Garden
Starter rope broke on yard machine
Take the top off. Remove broken rope. Rewind spring until tight, then unwind one turn. Insert and knot new rope.
Jun 07, 2009 | Mtd 22" Yard Machine Push Mower
Lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
May 19, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
670 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
