Question about Goodman GMS90703BXA Heater
Heat chamber replacement
Need info on replaceing a heat chamber on a airpak goodman
  • 1,420 Answers
Call Goodman at 713-861-2500. They are too cheap to have a toll free number. I'll warn you, this is not an easy job and you will need to tag every wire and part for reassembly. If you do it wrong, you have a very likely chance the unit will produce Carbon Monoxide and could kill you. I’m not joking!
Posted on Nov 01, 2007
What caused a loud, low frequency noise upon ignition.
Water in the heating chamber will cause your heater to make these sounds. If your water is cold, it will create condensation inside of the heating chamber. Another way water would get into the heating chamber is if your heat exchangers are leaking. Id check to make sure that heating chamber is not full of water, if theres any real accumulation of water, 2" or more, inside that chamber, the exchanger needs replacing. Otherwise, it sounds like condensation.
Feb 23, 2015 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
I would like to know how to replace the heat strips in an Amana GPH1330M41 unit
Buy a heat kit from a Goodman dealer. Check that your existing wire will carry the amp load.
Jan 17, 2014 | Goodman Manufacturing Goodman GPH1330M41...
Goodman model aruf486016AA is not blowing hot air
Need more info. Does blower come on when calling for heat?
Nov 11, 2013 | Goodman Manufacturing Goodman ARUF486016...
Bad compressor, need to replace it, need info on a replacement compressor.
Since you have a Goodman now, replacing it with another one is a good option.
The link below, should provide you with valuable information on what you need to choose. Based on square footage of your home, it's energy efficiency, etc.
http://www.goodmanmfg.com/ResidentialProducts/AirConditioners/tabid/1307/Default.aspx
Jul 07, 2011 | Goodman CKL36AR36 Air Conditioner
I had a goodman ARUF split system installed 8-25-09.Since then the heat exchanger blower motot replaced,cost $602.75,outdoor condenser unit fan motor to be replaced $592,00,recommend 5/8xing...
Hello, Usually it has to do with the quality of the install and the brand. If it was not installed properly from the beginning then the equipment will fail prematurely. As far as the heat exchanger goes I have replaced many heat exchangers on Goodmans after 3 years being installed, Goodmans are prone to bad heat exchangers.
Mar 05, 2011 | Goodman Heating & Cooling
Needs to register equipment for extended parts warranty for a goodman air conditioning & heating
there should have been paper work with the homeowners kit. If not goodman will mail the warranty info but you will need the installation invoice or receipt. The agreement is with goodman and the homeowner directly.
Aug 13, 2009 | Goodman Heating & Cooling
I have a Goodman GMMT 100-4B furnace I purchased and had installed in October of 2003. I sent in my warranty card, but I cannot find a copy of my warranty. The heat exchanger is cracked and I need to know...
Contact GMC in Houston Texas. The have an 800 number. You will have to have the model and seril number if this is still shown in date for their warranty then you'll just have freight to pay. Otherwise you'll need a copy of your check or statement or reciept where you bought it witth the dealer or place you bought it. The SN and MN are all the factory will have to verify when made.If it sat in someones warehouse 2 or 4 years you'll need your proof of purchase to make it go 10 years from purchase.
If this helps PLEASE GRADE NE ACCORDINGLY. If You need more info I need more info. THANKS AND GOOD LUCK!!
Mar 02, 2009 | Goodman Heating & Cooling
Blower will not turn off
there is a fan switch that senses the temperature in the heat chamber that turns the blower on when reaches temperature and off when it cools down enough sounds like it went out. should be black cover or metal box on front of chamber with wires going to it. good luck
Oct 22, 2008 | Goodman GMS90703BXA Heater
Replacement handle
I'M TRYING TO FIND THE HEAT CONTROL KNOB FOR THE WHITE CORNING WARE SLOW COOKER
Oct 28, 2007 | Rival 33511 5-Quart
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
