Question about HP OfficeJet J4580 All-In-One Laser Printer
Loading fax paper (direction?)
Which way do I put my document in the fax feeder to send a fax correctly?
    Scholar:
  • 149 Answers
Normally, there is a diagram engraved on the document feeder that indicates which way to orient your paper originals. However, if I had to take a guess, I would put them "Face Up" and "Top First"... meaning the top of the page goes into the feeder first. Good luck God bless -Carlos:
Posted on Jun 16, 2009
    President:
  • 828 Answers
Read the manuals properly...
My mfc 6490cw sends blank faxes
Normally this is caused by not loading the item being faxed in the ADF (Auto Document Feeder) correctly. Try sending a Fax of only one page by putting the page Face down on the Scanner plate (Lift the top of the printer to access the scanner plate). if this works then check the ADF scanner plate is not obscured.
Oct 20, 2014 | Brother MFC-6490CW Inkjet All-in-One...
CLX-3185FW I would like to know how to send a fax overseas. Where do I put the paper to be send? Thanks
You are talking about a Samsung all in one printer model CLX3185 and not a PDA right? You can put the document that you want to fax into the automatic feeder on the top of the printer or directly on top of the glass - your choice. If you use the auto feeder on top of the printer, look for a picture of paper near the insertion point that shows you whether the text side goes down or up when you put the paper in. If using the glass on the flat bed, the text goes down.
Once the document is loaded in either place, push the button that says "fax" and enter the number with the Country Code first and then press start. The line you are using to fax should have international calling enabled in order for this to go overseas.
Sep 14, 2011 | RIM Computers & Internet
I am trying to send a fax on my parents fax machine but do not know which way to insert the paper. It is a brother MFC-7860DW
  • if you are going to fax from the glass or scanner bed you should put your document face down on the glass
  • if you are going to fax from the feeder (on the top of the machine) then you should load your document face up in the feeder
How to send a fax?
  • when you want to send a fax ,press the FAX key to illuminate it in blue
  • put the document either in the feeder or on the glass
  • enter the fax number using the dial pad
  • press START
Jul 29, 2011 | Brother Office Equipment & Supplies
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
In what direction to you put in the paper when sending a fax? Up or Down?Front or Back? Thanks
Up or down doesn't matter much, as the recipient can always turn the printout around :) But generally putting the documents upside down will make the fax scan the top of the page first.
As far as front/back is concerned, it depends on the construction - if you look at the document feeder you will see a symbol of a sheet with a corner bent, showing the back side. If there are stripes (symbolizing text) on that corner, you must put the document(s) face down; if the stripes are on the rest of "sheet" - put them face up.
In your case most probably it will be face down. You can always check that, and the quality of document scanning (whether the document is not too light for example) by using the "Copy" function of your fax.
Dec 21, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
How do i fax multi pages at once
Your document feeder should allow you it install a stack of originals, amount depends on machine specifications. Dial one number and send your multi-page document.
if not the feeder tires may need to be cleaned, a few drops of alcohol in the center of a clean piece of paper then run it through the feeder, put the paper in then when it stops press the stop button and it should eject the document, in doing so pass the alcohol past the feed tires. do this a couple of times then try your multi-page document again.
Hope this helps
Ed
May 04, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Help when i try to fax using my brothers 560, the number dials, the machine sounds like it's faxing, but the disply says telphone. how can i correctthis
Do you pick up the hand set when you are dialing, If you do the display will read telephone. When you want to send a fax put the paper in the document feeder. Dial the # press the start key or put the documents in the document feeder press the hook button to here the dial tone, dial the number what for the tones pres the start key. hope this helps
C.W.H.
Jan 29, 2009 | Brother IntelliFAX 560 Plain Paper Fax
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
HP OfficeJet J4580 All-In-One Laser Printer Logo
207 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
