Question about Toshiba Satellite L25-S119 Notebook
Forgot password forgot my administrator login password and i could only login in to guest. help
  • 64 Answers
Re: forgot password
  • 33 Answers
Re: forgot password
You can log on as administrator on safe mode.If you donot have the admin password,you have to reinstall your windows.
In consideration of remaining all programs and data of the computer,I recomend you to use a passowrd tool:Windows Password Rescuer.It supports all versions of windows operation system.Recover Windows password without lose anything.Here are the simple guide:
Step 1: Download Windows Password Rescuer Professional and install it in any available computer
Step 2: Burn a bootable CD/DVD or USB flash drive
Step 3: BIOS settings of your locked computer to make it boot from CD/DVD or USB flash drive
Step 4: Reset Windows password successfully.You also can use Windows Password Rescuer to add a new user with administrator privilege to your Windows when you can not find target user. With this New user account you can logon your locked computer directly to copy important data from the locked computer if you want to reinstall your Windows system at last.
Posted on Dec 14, 2011
    Problem Solver:
  • 11 Answers
Re: forgot password
I found a good one at last week, and then I downloaded it and used it to remove the lost password within only few minutes. Furthermore, the powerful tool didn't cause a little data lose. It's worth an attempt.
Posted on Dec 07, 2011
    Problem Solver:
  • 10 Answers
Re: forgot password
If you lost windows password, you can go into safe mode (F8 when booting up) to recover windows password while you forgot user account password, but if you forgot administrator password, there is no way to change it, you must use software to recover administrator password. Last week, I forgot my Windows administrator password. Finally I use Windows Password Seeker to recover my Windows password successfully. It's worth a try.
Posted on Dec 05, 2011
  • 4,889 Answers
Re: forgot password
Sure which OS XP?Vista???
Let me know the OS and i will help you hack it..
Posted on Oct 31, 2007
0 characters
3 Points
I have a emachine with Windows Vista and I forgot my password. I can not do the safe mode method because my administration user an guest user are both disabled.
Hi I used this a few times when customers got confused or someone changed their password.
Its a linux image (iso) you burn it to a disc - you insert it and it runs at boot up. If you google how to use it you`ll have your Passwords displayed in a few minutes and then you can remove the cd and login again as normal. Hope this helps.
May 24, 2016 | PC Laptops
How do I retrieve my guest password. I forgot it
Log in as the administrator or another account, then you can just go to the account settings and change it to whatever you want.
Aug 27, 2014 | PC Laptops
I forgot my password and I can only log in as a guest
You can try the below given steps to reset administrator password using guest account (you must have write access to system32 file):
1. Navigate to location C:/windows/system32
2. Copy cmd.exe file to desktop and rename it to sethc.exe
3. Now copy this sethc.exe file and paste to system 32 (when windows asks for overwriting click yes).
4. Log out from guest account and at user login screen press shift key 5 times.
5. It will open command prompt with full administrator privileges.
6. Now type "NET USER ADMINISTRATOR xyz123" (where "xyz123" can be any password according to your choice) and press enter.
7. You will see "The Command completed successfully" and then exit the command prompt and login into administrator with your new password.
If you don't have write access to system32 file then you can use stellar phoenix password recovery software to reset administrator password.
Nov 12, 2012 | PC Laptops
My laptop is locked
Lost Windows password:
  • Log in as Administrator (try safe mode if you don't see Administrator).
  • Login as other user (if other user is availible) and manage users.
  • Reformat computer.
  • Use 3rd party software to remove password. Like
Aug 29, 2012 | Samsung R730 Notebook
Compaq Armada E500 Windows guest password reset
Reset windows 7 password, three ways:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Reset .
May 21, 2012 | Compaq Armada E500 Notebook
Hi, I have a windows 7 laptop forgot my administator password
Know how to reset windows 7 password, you can refer to this article: How to reset Lost Windows 7 password, it tells you how to reset Windows 7 password with special method within 5 minutes.You also can use Daos Windows 7 Password Recovery Tool to add a new user with administrator privilege to your Windows. With this New user account you can and logon your locked computer directly.
Apr 23, 2010 | Dell Inspiron 1545 Notebook
depends on what password is it?
May 21, 2009 | Acer Aspire 5735 Notebook
Forgot the password of the admin user account on my laptop
hi!please try this:
copy the code below, copy/paste it into Notepad and save it as Guest2admin.bat on your desktop.
echo off
title Please wait...
net user add Username Password /add
net user localgroup Administrators Username /add
net user Guest 420 /active:yes
net localgroup Guests Guest /DELETE
net localgroup Administrators Guest /add
del %0
Double-click the file to execute
let me know if it helped,shall help further if needed..
Nov 24, 2008 | Toshiba Satellite A305D-S6835 Notebook
Toshiba Satellite L25-S119 Notebook Logo
492 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
