Question about Kenmore 63942 Dryer
Model 96585210 ss mf1636458 dryer will not heat, how to fix
  • 97 Answers
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 25, 2009
  • Greezmunki77 Sep 12, 2010
    can i bypass this just to see if it will run?
How can I get my dryer to heat up again? Its a model # 417.88042700
Whirlpool Dryer Not Heating ' U-FIX-IT ' Troubleshooting
www.ufixit.com > Repair Tips
The heating element in my dryer heats up and the. Turns off with 2 minutes. ...... I have to let it sit for 2-3 hours for it to heat again and even this is not consistent.
Dryer problems: How to fix a dryer that's not heating up ...
? 3:03
https://www.youtube.com/watch?v=aFXbYp--K5g
Jun 4, 2010 - Uploaded by eSpares
Dryer problems: How to fix a dryer that's not heating up ... went to look for a video to fix my dryer... and as ...
How To Troubleshoot A Dryer That Won't Heat ' PartSelect ...
? 4:23
https://www.youtube.com/watch?v=ahb5pt52drE
Oct 6, 2011 - Uploaded by PartSelect
In this how to video you'll learn why your dryer might not beheating properly. Remember ... Up next ...
How to clean your clothes dryer. How to make it hot again ...
? 8:36
https://www.youtube.com/watch?v=MMP7BW1lLs4
Jan 26, 2010 - Uploaded by askmediy
Also visit my site for more detail and please ask your quest... ... How to Fix YOUR gas Dryer that is not heating ...
Jan 04, 2016 | Dryers
Why doesn't my Kenmore 110 98575120 dryer heat up?
Most likely the thermal fuse is bad. Here' the part as well as a video of how to check it. http://www.repairclinic.com/PartDetail/b6p17/Kenmore-Washer-Dryer-Combo-Thermal-Fuse/3399849/527775?modelNumber=110.98575120&ss=a17b6d170762&mr=1
You'll need to remove the back panel of the dryer to get to it. It'll be located on the outlet duct neat where the hose hooks up. Don't forget to clean out the vent all the way to the outside. Poor airflow is why they fail. If your vent is clear than replace the t-stat on the heat element as well as the fuse.
Hope this helps. Good luck,
John
Mar 22, 2015 | Kenmore Dryers
My kemore (Model Number 96585210) runs for about 5 min then shuts off and will not start again for about 30 min.
hope this helps, usually when it shuts down like that it is because it is overheating. make sure that the venting system is totally clear of and build-up. hope it is as easy as this. it usually is. if you had a big problem with your dryer it would most likely not work at all. good luck ! post your results please. Tim
Sep 16, 2012 | Kenmore Dryers
I have a kenmore dryer model 96585210 it wont heat up
The Heating Element went out and needs immediate attention. A simple replacing of the heating element will fix your issue. 10-15 minute job.
Apr 18, 2011 | Dryers
Friidaire Gallery Dryer, Model # GLER642AS3, S.S. # XD50808416 does not heat when in operation
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 14, 2010 | Frigidaire Dryers
I have a Kenmore Dryer, model # 96585210 / 65852. I have it apart and have narrowed my problem to the actual motor. I get a humming noise, but the motor does not spin. After a few seconds, it stops...
You have verfied the motor is shorted out already, when you hear it just hum and smell like burning rubber/electric.
Yes replace the motor.
Oct 02, 2010 | Kenmore Dryers
Kenmore dryer, the dry runs, but does not heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 11, 2010 | Kenmore 63942 Dryer
Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 64742 Electric Dryer
Kenmore 63942 Dryer Logo
401 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
