Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
USB DRIVE NOT ACESSABlE
When i connect my usb drive it appear in my computer but when i tried to open it a message appears that "disk is not formatted format it now".. but when i insert the same usb in other PC's usb open and i can access it..what is the problem with my PC.
  • 2 more comments
  • fburiro Jun 16, 2009
    I m having windows XP..this is problem occurs with every usb that i onnected with my PC...this problem arise a two months ago...before that i was using usb drive in my PC normally.
    i think my usb drive..driver is not compatible..or its because of a virus in my PC.
    i have 4 usb ports..and same message appear when i connect any usb drive thru them
  • Carlos Soto
    Carlos Soto May 11, 2010
    OK, take the USB drives and put them in another computer, if they work, the problem is with the PC. If they don't, then problem is probably the drives.
    Put them in another system and report back please.
  • Carlos Soto
    Is the PC where you can't read the drive, USB2.0 compatible? What is the USB version on the PC that works?
    Is this the only USB that this PC can't read? Or is it every USB disc?
    If you have important data on that USB, I would suggest in copying it on the 2nd PC and format it on the first PC. If after formatting you can see the device, put it on the second PC, copy your data over to the newly formatted USB and take it back to the first PC and report what happens.
    President:
  • 828 Answers
Youve got a problem with you USB connection in your PC... try to use another USB connection...
Posted on Jun 16, 2009
How to unlock partition on flash drive
USB flash drives are small, convenient storage drives. Place data such as pictures, photos and text on them quickly and efficiently and then carry it to another computer for copying to its hard drive.
A USB flash drive that has security enabled in it must be 'unlocked" before it can be used, which becomes difficult if the password has been lost. Because the security on the USB flash drive is rudimentary, a number of methods, from built-in software to optional programs, can remove the security so that the drive can be used.
Plug the USB connector of the USB flash drive into a USB port on the PC. Right-click on the icon of the USB flash drive when it appears on the desktop of a Windows-based computer. Select "Format" from the pop-up menu. Follow the command prompts in the window that appears to format the USB flash drive. Click "Done" in the confirmation window when it appears. The USB flash drive can now be used because the security has been removed from its storage space. Plug the USB connector of the USB flash drive into a USB port on the Mac. Double-click on the Mac's Disk Utility program, which comes free with the OS X operating system and is in the "Utilities" folder on the hard drive. Select the icon of the USB flash drive in the left column of the Disk Utility program's main screen. Select the "Erase" tab at the top of the Disk Utility program's main screen. Click on the "Format" check box on the right side of the Disk Utility program's main screen. Select "Fat (32)" from the drop down menu below the "Format" check box. Click "Format" at the bottom of the Disk Utility program's main screen. Click "Format", again, in the confirmation box that appears. Quit the Disk Utility program when the formatting is done. The USB flash drive can now be used because the security has been removed from its storage space. Download a password protection program to the computer's desktop; for example, the free TrueCrypt password protection program (see the link Below). http://www.truecrypt.org/downloads Double-click on the icon of the password protection program when it has fully downloaded. Follow the command prompts to install the program onto the computer's hard drive. Restart the PC after the installation has been completed. Double-click on the password protection program to launch it. Wait for the password protection program to recognize the USB flash drive and display disc letters for the drives attached to the computer in the left column of its main program screen. Plug the USB connector of the USB flash drive into a USB port on the computer. Wait for a letter to appear in the left column of the password protection program's main screen. Use the mouse to click once on this letter which represents the USB flash drive. Click on the "Volume" or "Volume Tools" button to open a new window. Click on the "Next" button in the new window. Erase the password in the "Password" column of the new window that appears. Erase the password in the "Confirm password" column. Click on the "Next" button to go to a new screen. Select "Traveler Disk Setup" from the drop down menu below "Tools" at the top of the password protection screen. Click on the "Open Explorer window for mounted volume" check box in the new window that appears. Click the "Create" button at the bottom of the window. Click the "OK" button on the confirmation window when it appears. Quit the password protection program. Drag the icon of the USB flash drive to the Trash or right-click on it and select "Eject" from the pop-up menu. Remove the USB flash drive from the computer's USB port. Plug the connector of the USB flash drive back into the computer's USB port. Double-click on the icon of the USB flash drive when it appears on the desktop to open its window now that the security password has been removed. Plug the USB connector of the USB flash drive into a USB port on the PC. Go to "Start" and select "Run" from the pop-up menu. Enter "regedit" into the text column that appears and press the "enter" key to run the registry editor. Press the "Browse" button on the registry editor's main screen and navigate to the following path on the computer's hard drive: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies" Click "OK" to close the window. Double-click on the "WriteProtect" text that is in the right column of the registry editor's main screen. Enter "O" into the "Value Data box" in the window that appears. Click on the "OK" button to close the window. Quit the registry editor program. Restart the PC. Double-click on the icon of the USB flash drive that is on the desktop to open its window and access the files now that the security write protection has been removed.
Hope this helps.
Jan 17, 2013 | SanDisk Electronics - Others
I can't open because of the paSSWORD IN IT.
Hope this helps.
Jan 17, 2013 | SanDisk 2GB microSD Memory Card
Un lock my pasword
Which is it a 2 gb cruzer or 1000 gb ??
Plug the USB connector of the USB flash drive into a USB port on the PC. Right-click on the icon of the USB flash drive when it appears on the desktop of a Windows-based computer. Select "Format" from the pop-up menu. Follow the command prompts in the window that appears to format the USB flash drive. Click "Done" in the confirmation window when it appears. The USB flash drive can now be used because the security has been removed from its storage space. Plug the USB connector of the USB flash drive into a USB port on the Mac. Double-click on the Mac's Disk Utility program, which comes free with the OS X operating system and is in the "Utilities" folder on the hard drive. Select the icon of the USB flash drive in the left column of the Disk Utility program's main screen. Select the "Erase" tab at the top of the Disk Utility program's main screen. Click on the "Format" check box on the right side of the Disk Utility program's main screen. Select "Fat (32)" from the drop down menu below the "Format" check box. Click "Format" at the bottom of the Disk Utility program's main screen. Click "Format", again, in the confirmation box that appears. Quit the Disk Utility program when the formatting is done. The USB flash drive can now be used because the security has been removed from its storage space. Download a password protection program to the computer's desktop; for example, the free TrueCrypt password protection program (see the link in Resources). Double-click on the icon of the password protection program when it has fully downloaded. Follow the command prompts to install the program onto the computer's hard drive. Restart the PC after the installation has been completed. Double-click on the password protection program to launch it. Wait for the password protection program to recognize the USB flash drive and display disc letters for the drives attached to the computer in the left column of its main program screen. Plug the USB connector of the USB flash drive into a USB port on the computer. Wait for a letter to appear in the left column of the password protection program's main screen. Use the mouse to click once on this letter which represents the USB flash drive. Click on the "Volume" or "Volume Tools" button to open a new window. Click on the "Next" button in the new window. Erase the password in the "Password" column of the new window that appears. Erase the password in the "Confirm password" column. Click on the "Next" button to go to a new screen. Select "Traveler Disk Setup" from the drop down menu below "Tools" at the top of the password protection screen. Click on the "Open Explorer window for mounted volume" check box in the new window that appears. Click the "Create" button at the bottom of the window. Click the "OK" button on the confirmation window when it appears. Quit the password protection program. Drag the icon of the USB flash drive to the Trash or right-click on it and select "Eject" from the pop-up menu. Remove the USB flash drive from the computer's USB port. Plug the connector of the USB flash drive back into the computer's USB port. Double-click on the icon of the USB flash drive when it appears on the desktop to open its window now that the security password has been removed. Plug the USB connector of the USB flash drive into a USB port on the PC. Go to "Start" and select "Run" from the pop-up menu. Enter "regedit" into the text column that appears and press the "enter" key to run the registry editor. Press the "Browse" button on the registry editor's main screen and navigate to the following path on the computer's hard drive: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies" Click "OK" to close the window. Double-click on the "WriteProtect" text that is in the right column of the registry editor's main screen. Enter "O" into the "Value Data box" in the window that appears. Click on the "OK" button to close the window. Quit the registry editor program. Restart the PC. Double-click on the icon of the USB flash drive that is on the desktop to open its window and access the files now that the security write protection has been removed. Hope this helps
Dec 20, 2012 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
The disk driver is not formated do you want
Flash drives are composed of a memory chip/ storage and USB interface. The above message appears only when the USB interface is working but memory area is faulty. Unfortunately, the chip replacement is not possible.
To confirm that the problem is with the memory area, right click on my computer - goto manage, then disk management and look for flash drive. The flash will appear but no memory would appear.
Flash drives are mostly under warranty for atleast one year. Claim warranty, if possible.
Hope this helps!
CreativeTECH
Nov 10, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have 2 Lacie 2TB external drives. 1 of them does not appear anymore on my desktop it did the other day off and on. 1 or 2 times in the rebooting a disk formating pop up appeared saying it did not...
Try changing the USB port to connect it. Also try substituting the cable used to connect the errant disk. It may be a cable issue or a USB port on your computer.
Sep 08, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
My USB giving message of Insert a Disk into drive !
Your USB IS DAMAGED TRY TO PULL OF THE COVER OF THE USB DAN CLEAN IT WITH A TOOTH BRUSH OR ANY SOFT BRUSH DAN PUT IT BACK TO YOUR COMPUTER AND GO STRAIGHT TO MY COMPUTER AND FORMAT IT USING QUICK FORMAT SYSTEM. :)
Apr 16, 2010 | Electronics - Others
MY PENDRIVE IS NOT ACCESSIBLE . WHEN OPENED MESSAGE APPEARS INSERT DISK IN DRIVE:E
First try another computer if the same problem appear, try to open the system of the pc by pressing F2 or F10 depending on your BIOS and select USB boot device there.Restart the computer and try to load the pendrive. Another you may need to installe USB driver from your motherboard installer.
Jan 26, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Computer crashed while USB was inserted. USB will no longer open.
Scan you pendrive for Virus from another computer who has effective antivirus program & it have latest Update.
Norton is my trusted.
Thanks.
Oct 06, 2009 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Pen drive does not open
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
Jun 17, 2008 | Computers & Internet
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
180 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
