Question about Canon imageRUNNER 400S Copier
I have a imagerunner 600 that is displaying an error code of E014. Any idea of what the problem could be?
    Sniper:
  • 54 Answers
Its a fixing motor error.check the fuser unit will be rotating smoothly or not , if its good replace the fixing motor
Posted on Jun 18, 2009
How to fix error code E014, it shows on screen switch main power off and on then E014, but I turned off and on many time , it stay like that
If I remember correctly..... A E014 mean that the main drive is not spining freely. Most of the time the fuser unit is not turning smoothly. Have you tried to spin the fuser unit? If so is it smooh or tight? Have you looked in the fuser to see if the web is wraped around the upper fuser roller? Or is the lower fusing roller cut? If that all looks OK > it is the fuser drive gears (on the front of the fuser) are locked up... You may have to take the two white gears off and clean & lubract / oil the shafts.... Good Luck > there is not a way to reset the code until it is fixed
Feb 04, 2011 | Canon imageRUNNER 400S Copier
E000007-0000 Error
The Canon imageRUNNER 3300 System error e007 code means that the fusing film is out of Home Postion or the film is ripped. You will need to most likely have the fixing film replaced. You are proble going to have to get a service to repair it.
http://www.fixya.com/support/t6195187-cannon_ir2018_system_error_e007
Oct 25, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
No print, e805 and e014
The E 805 refers to a locked up fan motor, and the e014 is for the fuser (the part that get hot) not turning correctly. both of these problems require a technician to fix.
Jul 29, 2009 | Canon imageRUNNER 400S Copier
I am having Cannon IR 400 .please help me in solving the problem of error E014 & some times is soing E 051,E 901,
Hello sir ; All the code you display are motor problem ,check the fuser unit motor first and then go to main motor, most likel is maint motor have problem, if that true replace it ,that is only way you can do.
Jun 13, 2009 | Canon imageRUNNER 400S Copier
CANON GP405 ERROR E014 PROBLEM
when I start my machine the error code e014 appears and machine do not run.
Dec 24, 2008 | Canon imageRUNNER 400S Copier
Error code E014 on a canon imagerunner 330s
This needs a new fuser unit or it needs rebuilt. Bearings are locked up or its very stiff. If the fuser is in good working order then a new fixing unit motor is needed.
Oct 24, 2008 | Office Equipment & Supplies
Canon imageRUNNER 400S Copier Logo
98 people viewed this question
old marine
old marine
