Question about HP Officejet Pro L7680 All-In-One Printer
The top feeder gets jammed = seems to be a problem with the blue
And white bar that directs the paper when the printer scan window is open...
  • HP Master
  • 365 Answers
Open the lid and clean the rollers with Isopropal Alcohol.
It should also be under warranty!
Posted on Jun 16, 2009
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
Top feeder jam
Yes. When removing a jam, it is never wise to "aggressively" remove the paper, as it can break switches, gears, etc. maybe any switches or gears had damanged, need replacement of that parts.
Feb 25, 2010 | Samsung SCX4824FN Mono All-in-One Laser...
Dark, vertical stripe on copy on Sharp AR-M160
Have you cleaned the small, narrow glass window leftmost of the platen? It is directly above the scanning bar's "home" position, and that's where the document is scanned, while it's fed by the feeder, passing over the bar (the paper moves, as oposed to platen scanning, when the bar is moving and document remains still).
Feb 10, 2010 | Sharp AR-M160 Laser Printer
When trying to fax I get an error "open adf cover"...
You should be able to. It sounds like you've got a paper jam in the document feeder. Chances are there was a jam and part of the document (a small peice perhaps) is still lodged in the document feeder unit.
Aug 31, 2009 | Konica Minolta PagePro 1390MF All-In-One...
Doc. feeder jam, after paper removed completely
HP LaserJet 3030 All-In-One Printer
Mar 11, 2009 | HP LaserJet 3030 All-In-One Printer
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Paper jams
It sounds like you'll need new feed rollers.  I could find some part #s for you if you felt confident replacing them yourself.
Oct 10, 2007 | Dell 1600n All-In-One Laser Printer
Auto-Feeder Does not feed paper evenly
There must be a small jam in the feeder. You can try sliding a business card or heavier plastic card through the feeder all the way across. Chances are it will push whatever is stuck in there out.
Jul 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
