Question about Cnet CSH-2402G
Switch CNET CSH-2402G PASSWORD RECOVERY
Need access to serial console of the SW, but the default password provide by CNET (123), not work
Thank's
  • 689 Answers
It should be 4 digit 1234 if still doesn't work you may try reset
Good Luck
Posted on Jul 27, 2009
I cannot connect using serial console port (no signal / data out of serial console port). I don't have IP address of the DS4100B. I don't have its password... How can I reset it to factory default?
I am assuming you will still need console connection to do a password recovery.. however, here is the link to one password recovery doc that may help.
May 10, 2016 | EMC DS-4100B 32 Port 4Gb SAN Switch
How do i configure the CNET 16ports switch to allow or not web access through?
Unless I'm missing something, you can't. This is a basic switch with no advanced application aware features.
May 02, 2015 | Cnet CSH-1600E 16-port 10/100Mbps Fast...
How to reset the switch CNET CSH-1600
No manual. Maybe a pinhole reset switch?
Mar 28, 2014 | Cnet (CSH-1600) (CSH1600)
I forgot ip address and password and want to factory reset
Connect the console cable, open a connection to the serial port via a utility such as PuTTY, and do the following:
1) Enter the user name "recover" and password "recover" to place your unit in password recovery mode. The unit will remain in password recovery mode for 30 seconds max.
2) Perform a hard reset by removing power, waiting 10 seconds, and then re-applying power.
3) Once the switch has rebooted, enter a new password for the "admin" user account.
4) Enter enable to leave password recovery enabled, or enter disable to turn it off. You are now logged in as the default "admin" user.
Note: If password recovery has been disabled, the only way to recover access is to return the switch to 3com.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
Pleased i need to download the remote management software (rmt) for cnet csh 2400 switch. where can i do this
Don't know about a special program, but you can try to use Centrastage (www.centrastage.com)
It's a remote management software and it seems like it can be useful for you.
Jun 29, 2011 | Cnet CSH-2400 (csh2400) 24x10/100 Mbps...
Which type of cat-5 cable do i use to connect a cnet switch to a d-link switch
interConnecting two switches will need a crossover cable. Please use a crossover cable.
Oct 27, 2010 | Cnet CSH-800 8-Port Ethernet Switch
Cnet CSH-800 8-Port Ethernet Switch no power
Check the power adapter with a multi-meter. The voltage on the plug that connects into the Ethernet switch, the voltage reading should be slightly higher than the voltage that is printed on the label on the bottom of the adapter.
If the voltage is zero or very low then the adapter is faulty and needs to be replaced.
If the voltage of the adapter is OK then the Ethernet switch is faulty and you need to buy a new one.
Dec 11, 2009 | Cnet CSH-800 8-Port Ethernet Switch
Don't have internet connection
This particular 8-port Ethernet switch/hub has auto-negotiation on both speed as well as MDI, MDI-X.  Therefore, the problem is not with your switch/hub, it's probably with the particular port that you're connecting it to on your Router.  Make sure that it's the LAN side, not the WAN side.
Mar 14, 2009 | Cnet CSH-800 8-Port Ethernet Switch
Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
Mar 05, 2009 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
Password Recovery
The login you are using should have placed you in super-user mode. Are you connected directly to the switch with a serial console cable?
Jan 09, 2008 | Computers & Internet
Cnet CSH-2402G Logo
253 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
ddalecki
matt
matt
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
