Question about IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR KIT-Air Brush
My iwata hpc is pushing air back through the paint cup
When i start to paint the paint bubble back out of the paint cup but air is still coming out the front of the gun like it should but no paint out the front
  • Catherine Nally May 08, 2013
    Would be helpful to say how to check seals and O rings
  • 4 Answers
Try replacing cup gasket first then clean all inlets and outlets completely, check that all valves operate properally, and all seals and o-rings are in good condition. Clean and lubricate adjustment fluid valve.
Posted on Jul 30, 2009
We have 2 problems. First, while painting, paint is leaking out of top of cup. It didn't do that the first time. Second, its spitting and leaving tiny bubbles.
First checkthe sealin the cup lid make sure its seated right and thelid is screwed tight second check your pressure is high enough and thatyour spray tip is cleanand free from any dry paint
Mar 23, 2017 | Air Tools & Compressors
Tip
How to clean your air brush to keep it like new
Taking care of your tools and supplies is an essential in their upkeep and increasing the life of your tools. When you neglect to take care of your tools they will get clogged or ruined and eventually will stop working. This same principle applies to your air brush gun, if you don't take care of it and clean in properly after each use it will get clogged and will stop working.
After each use you want to make sure that you get all the paint out, to do this you should add a little bit of warm water to the cup (where the paint goes in) and then pour it out into the trash. You must be sure NOT to use hot water because it could melt or warp small plastic pieces inside the gun.
Fill a bowl or tub with clean warm water, connect the air brush to the tube, plug it in and turn it on. Placing the needle and the cup under the water and pull the trigger. Run water through it for a few minutes to make sure that no color comes out of it. If paint does come out of the gun you will need to change the water.
When the water runs clear through the gun take it out of the water and fill the cup with clean water. While placing your finger over the needle cap pull the trigger. This will make the air flow backwards through the gun causing bubbles to form in the cup. If there is paint stuck in the gun it will come up in the bubbles in this step. Pour the water out and place the needle and cup in water again and pull the trigger.
When you feel that it is clean, take the gun out of the water and spray your gun on a white napkin or paper towel to make sure there is no color in the spray. If no color comes out you are all clean and ready to use your airbrush gun again.
on Feb 06, 2014 | Air Tools & Compressors
Master g22 air paint
Do you have a water separator attached?
Jul 11, 2013 | Crafts & Hobbies
I am using an iwata eclipse cs airbrush with an iwata compressor. the comopressor seems to be working fine when power, but the airbrush is not getting and air. when i push down for air release, nothing...
Air brushes us a Theory called a "venturi" in where air pressure lowers the pressure where the paint is kept and causes it to go out the nozzle. I would try seeing if there is an obstruction in the hoses to the brush and confirm that the compressor is moving air. If none of these things are an issue also while cleaning the parts may give the appearance that the item is clean then try soaking them over night in paint thinner and replacing the O-rings and gaskets.
Apr 27, 2011 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Water coming out airbush from hose
An in-line water separator should be used before the supply line, a good air filter wouldn't hurt either.
Apr 23, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
I cant decide between two airbrushes i am thinking on ordering.I want a large cup gravity feed and right now am debating between the Badger 100LG and the Paasche Talon.Any comments would be great
I am not familiar with either brush, but they are both well known name brands. The Paasche will probably have more readily available parts for it than the Badger in case something breaks or you drop it. I myself use Iwata, BUT the parts are expensive.
It will boil down to which brush comes with what size tip/needle in accordance to what type of media you will be shooting. Thicker paints or stains will require a bigger tip and needle, thinner paints and stains, just the opposite. I hope this helps.
Feb 21, 2010 | Paasche Talon Gravity Feed Airbrush Set
Bubbles in color cup of airbrush
I assume you have adjusted the nozzle... On my unit, there is a SMALL hole in the cap for the cups to let in air above the paint. Also OFTEN the paint must be thinned to use in an airbrush. Since you havent been able to draw water even, thinning is NOT the problem.
The airbrush aspirates the paint by Bernouli's principle, that is where there is higher velocity of a fluid, there is a lower pressure. The nozzle creates that and the adjustment is important. On mine which is a "Wren", I think by Binks there is a conical piece that the paint comes out of with a throttling needle. This has the be unscrewed to open the paint path and adjust it. The air flows at high speed around this cone creating a vacuum.
The headline says "Eclipse" but that is a gravity feed so I suspect that is the old Fixya problem of having incomplete choices to pick from.
Feb 18, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
I have some severe free flow goin on, on my hpbcs iwata eclipse
It sounds like you have a problem with the air valve. Possible deterioration of the valve material? I am not sure what they use, but if it is a rubber the cleaning thinner MAY have destroyed its properties if the cleaner got into the air path and valve.
Aug 12, 2009 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Total Novice
I suggest that you go to the Library and look up how to airbrush. The paint goes into the cup. Nozzle adjustments are learned as you go, for desired results. Good luck
Feb 01, 2009 | Badger Basket Starter Spray Gun Hobby Set
IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR KIT-Air Brush Logo
513 people viewed this question
Top Iwata Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Iwata Air Tool and Compressor Expert? Answer questions, earn points and help others
