Question about Toshiba 62HMX84 62" Rear Projection HDTV
Samsung Rear 42 in Projection TV Calibration problem
I have a samsung 42 in rear projection tv and the color is all wavy. Tried the auto calibration from the remote control and did not fix problem. Is there a cheap way to fix this or is it more expensive than what the TV is worth? It was purchased in 2004-2005.
  • 60 Answers
Hi, if you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Posted on Sep 17, 2009
2 Suggested Answers
  • 1030 Answers
SOURCE: Mitsubishi 55" Projection TV / Horizontal Wavy Lines at Start Up
this is very common with these sets. the fix is to replace 11 very very smal capacitor on what is known as the hypermodule. The ideal sitation is to replace the hypermodule. if you can find it. I can do this repair. I have done about 10 at the shop. if you need to i would suggest finding someone who is very experence in surface mounted repair
Posted on Jan 15, 2009
Intermittent vertical black lines samsung hlp5067w
even technicians who are familiar with those units, before installing new lamps, they use a 'calibration unit' for that or any particular model lamp and calibrate them right after installation. If you don't have the proper calibrator and adjust them right after you installed them, you will get that result. Even experience techs come across that problem if the calibration is not done properly. Also, each lamp for a different color value, has its own calibration/sync values.
Nov 18, 2013 | Televison & Video
Have a 50 inch hlp506w model samsung projector tv. it had wavy lines through it, and then turned off. it is continuing to try and turn on with the standby/temp and lamp lights flashing. replaced lamp...
Change the tv Ballast board too.This board only job are to help it to ignite the tv projection lamp. This tv also have a colors wheel design into it too.If tv have colors pictures flashes or Black& White flashes within it pictures or tv have grinding noises or humming sounds,than the tv colors wheel it is warp and dead.This tv colors wheel must be replaced,because the colors dis wheel is warn out.
Jul 05, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a samsung HCP4363wx/xaa rear projection tv, and everything on all chanels looks like its always in 3-D, text is unreadable, any ideas what might b wrong ??
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 24, 2010 | Samsung HC-P4241W 42" Rear Projection...
Demagnetize a Samsung SP46L5HX
This tv been hits or drop before?Tries move the tv around West,East,North so on help.Unplug replug for the dequaging coil inside to work.
Nov 22, 2009 | Samsung HCN4226W 42" Rear Projection...
Samsung 52'' DLP rear projection -- green tint after moving unit
http://web1.toshiba.ca/support//ceg/techsupport/tsbs/viewtsb.asp?docid=TSB000064
Nov 16, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung rear projection tv
It probably is see if you can align the convergence manually or auto if available, you can order just the convergence ic's or the convergence amp board, whichever you prefer. check pricing and availability. also check Blue crt for faded picture, usually dirty crt fluid, makes picture dark and discoloured. If it is you may need to replace the blue crt also. this gets a little expensive, again check pricing hope this gets you started RFT
Jan 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Green screen on tv
Grayscale. Could be in the Screen trimpots of the focus block as well.
Need an ISF calibration and/or rebalancing of the Screen trimpots.
Mr Bob
www.imageperfection.com
Dec 30, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Cant play My ipod on my Samsung TV
not detecting the side inputs?....try plugging the ipod into the audio input 1 and select video 1 on the input...if you hear sound...your ok
Apr 23, 2007 | Samsung HCM422W 42" Rear Projection...
Toshiba 62HMX84 62" Rear Projection HDTV Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
