Question about Black & Decker Black Decker 16" Hedge Trimmer
I need a copy of the owners maual for Black n Decker. When I turn it on the blades do not move but the gears inside are moving. Therefore it screams. Thanks.
    President:
  • 1,185 Answers
Do you use WD40 on the blades between sessions
If you have been cutting resinious branches there is more than a chance that the blades are seized together.
You could try putting the blades into a bucket of very hot soapy water (Without a power line attached or the battery removed )
Leave them to soak for a couple of hours, take them out of the water and give them a try, if they run then dry the blades off with a hair dryer and apply some oil to the surfaces.
If they donT then you have stripped the teeth on the gearbox and you may as well dump them as it will be cheaper to buy a new machine than it is to get B&D to repair it
Posted on Jun 16, 2009
    Top Expert:
  • Black & Decker Master
  • 16,623 Answers
The screams are the gears grinding down unplugged unscrew the plastic cover will see the motor and gear assembly if gear popped out of alignment pop back if broken or any patr of assembly is replace part do not yse a damaged part can seriously get hurt the link has the exploded view of the b&d hedge trimmers click or your model for the diagram
Black and Decker Hedge Trimmer Parts
Posted on Aug 13, 2016
    President:
  • 1,865 Answers
You have to dismantle the unit and realign the blades with the gears.
  • Emmeline
    Emmeline Aug 13, 2016
    how do you realign the gears?
Why is blade not moving?
Either the gears are trashed, OR SOME machines have a "CENTRIFUGAL CLUTCH" [a safety feature] between the engine and the blades. This is to ensure that the blades don't move when idling, and move when at full throttle.
IF your machine has this feature, then it's possible that the clutch has worn out and is slipping so badly that the blade won't move.
Jun 10, 2014 | Black & Decker Garden
Neuton cordless hedge trimmer may need new motor. the blade does not go back and forth
Primary gear on motor shaft may be stripped, no source for replacement known. I have the same problem motor runs but blades do not move.
Feb 19, 2012 | Black & Decker Garden
Blade wont move
there is a broken gear in the gear reduction box. (explain:) the motor spins at a high rpm, the chain moves at a 1/4 or less rpm than the motor. a series of gears reduces the speed, which in turn creates torque, allowing the saw to have the force to keep cutting without stopping. One of the gears is broken or a keyway on a shaft is sheared...as far as i know, no electrical power tools are rebuildable. it's a safety thing (electric shock if reassembled wrong...they are priced for replacement...get a new one...
Jun 06, 2010 | Black & Decker CCS818 Chain Saw
I have the black and decker grasshog (non cordless) which long turns. i've replaced the line, and it powers up but no turning of the wheel.
possible stripped plastic reduction gear (just inside bottom of motor housing). Make sure that no grass is bound up between moving and non moving parts. This is a chronic problem and will lock up the unit.
Apr 11, 2010 | Black & Decker String Trimmer Cordless 12"...
B&D Corded Circular Saw - Arbor Does Not Move
This model is not equipped with a clutch so its possible that the gears are stripped, shaft broken. If the blade moves freely then this is probably the case. If blade does not move freely, check for any foreign objects between blade and blade housing. I hope this has helped if you have any further questions don't hesitate to ask. Please rate on the helpfulness of the answer. Good Luck and have a great weekend.
Apr 04, 2010 | Black & Decker CS1012 7-1/4" 12 Amp...
The motor works but strimmer does not rotate
If the head does not turn, but the motor runs freely, then the reduction gear is damaged. It is inside the motor housing. If the motor tries to run but does not rotate, then there is likely material bound up between the moving and non-moving parts.
MANUAL:
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
PARTS:
http://www.ereplacementparts.com/black-and-decker-grass-trimmer-parts-c-4167_9518.html
Apr 02, 2010 | Black & Decker Garden
How do I remove the blade and reinstall a new blade in my Navigator saw. Thanks.
Before you can mount a new blade onto your black and decker navigator you must make sure the holding pin, (the flat side of the oval part) is paralell to the bottom of the saw. If it is not push the black button that pushes the pin out as hard as you can and with a small wrench move it into the proper position. Mount you blade @ 90 degrees and push it up into position
Oct 01, 2009 | Black & Decker 11-3/4" Navigator General...
Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Jul 14, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
Black & Decker Black Decker 16" Hedge Trimmer Logo
705 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
