Question about Tools & Hardware - Others
I have a Ryobi 4x36 Belt Sander (BD4600). I've only used it for a little over a year to sand plastic; nothing else. The sanding belt is not slipping; the drive belt is not slipping. However, now even under light pressure sanding, the motor makes a high-pitched whine and slows to a stop.
    Sergeant:
  • 384 Answers
Look for plastic build up in the motor. Try to air blow motor and belt drive.
Posted on Jun 16, 2009
Why does it cut sanding belts?
the belt alignment is WAY out of adjustment!!!!.. move the alignment OPPOSITE the way it is now..
Jan 25, 2016 | Sander Tools & Hardware - Others
Need a manual for a mastercraft 55-3554-4 sander
If you find best disc snaders in 2018, easy to assemble, easy to use go to the link Best Disc Sanders For Sanding In 2018
Dec 20, 2013 | Ryobi Mastercraft Belt/disc Sander Belt...
I have borrowed a ryobi industrial belt sander, I have put the sanding belt and repositioned the latch. When running the sanding belt keeps moving out.
There will be a tracking adjustment somewhere, usually a knob or wheel located at one end (axle) of the sander that allows you to adjust that... run the sander at low speed while you turn it until it tracks straight
Jun 10, 2011 | Tools & Hardware - Others
I have a Ryobi BE-321 belt sander. The drive belt is strtipped. Are replacement belts still available?
Yes, you can purchase a new belt here:
http://www.ereplacementparts.com/ryobi-be321-belt-sander-parts-c-7931_7932_15013.html
Luke
Oct 27, 2010 | Tools & Hardware - Others
Sanding belt will not stay in line. Slips over to the inside.
There is an adjustment screw on the side of the sander that aligns the belt. Mine has a black plastic knob on it. If adjusting this does not help, remove the belt and check to see if it is making contact with the belt roller frame. The screw on mine was too long and I had to shorten it on a grinder. If you do this, take only a little at a time, a small adjustment will move the belt quite a bit.
Aug 16, 2009 | Makita 9404 4'' x 24'' Belt Sander
Where can I find a sanding frame for a Ryobi EBS1310VK 3"x21"??? Thanks!!!
hello. as a fellow woodworker i share your frustration in locating this ryobi sanding frame. Ryobi does not show one at their .com site. here is a link to some other manufacturers sanding frames just in case you decide to buy a different brand sander that does have a sanding frame available
http://www.nextag.com/belt-sander-sanding-frame/compare-html
Aug 14, 2009 | Tools & Hardware - Others
Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Jan 09, 2009 | Tools & Hardware - Others
Belt slipping
I have a Ryobi sander with a belt slipping issue as well. The problem seems to be in the design, not on the user end. The drive barrel is made of a semi-hard, non-gripping material. Wood dust becomes a final release agent that breaks any grip that the barrel may have had.
To compound the problem, the more the belt slips the smother the underside becomes allowing for greater slippage.
I now know why this model was the least expensive unit. >.<
Jan 08, 2009 | Tools & Hardware - Others
Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Tools & Hardware - Others Logo
586 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
