Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon MP830 fault code 6B10
I get a 6B10 when I feed from the lower paper tray.
It works fine from the bypass tray.
Can anyone discribe the code?
  • Canon Master
  • 365 Answers
Try to change paper size in the offending tray.
Posted on Jun 16, 2009
6b10 error, meaning?
Hi this is what i found for your problem hope it helps thanks. Paper feed cam sensor error or Error Code 6B10
Condition: An error occurred in the paper feed cam sensor during paper feeding from the cassette, or the paper absorbing a large amount of ink jammed in the PF rear guide.
Problems and Solutions:
  • Jammed paper in the PF rear guide (when a large amount of ink was absorbed in the paper);
    - remove the jammed paper and foreign material.
  • check for foreign material or paper debris in the cassette or in the PF rear guide;
    - remove foreign material.
  • If other solution fail, replace one off the following part
    - PF pick-up unit
    - Logic board
Sep 21, 2011 | Canon PIXMA iP2000 InkJet Printer
Will not feed from lower tray. upper feeder works fine
If you have a error code on display please respond. I can give you more detailed information.
If not, make sure that the print job that you are sending to the printer is for the same size paper that is present in the paper tray. Also, check that the tray is adjusted properly to the size for the paper that is present.
You could try running an internal print job to bypass the settings.
Dec 28, 2010 | HP LaserJet P4014n Printer
I have a canon mp830 printer and the prompt says 'add paper'. there is plenty of paper. i have powered off several times and have changed and added paper, but it clicks and again says 'add paper' any...
hello, on the machines display/control panel there is a switch for paper feed, it might be set up for lower tray or back tray, depending on where you are feeding paper. also the computer usually overrides the printer, so might check to see if the paper setting on computer is set for the tray you are using.
Dec 27, 2010 | Office Equipment & Supplies
My Pc745 has stopped pulling paper from the tray without crunching it up
try to run paper from the side bypass tray. if still no go, you may have something blocking the paper from feeding. if it feed from the side bypass but not the cassette, paper feed tire may not be feeding paper or the out of paper sensor maybe keeping paper from reaching paper feed tire
Apr 11, 2010 | Canon Office Equipment & Supplies
Fault/error 6A00 for my canon MP830 flash light and no paper (fault) roller defect can I fix this ? John
6A00 is AP position error.Possible problems in:
- Sheet feed unit (QM2-1220)
- Logic board assembly (QM2-1520)
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Oct 28, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Error - Canon MP830
this Model has a paper tray on the bottom. Put some paper in the bottom tray and then voila..I had the same issue and i looked and the tray was empty..put some paper in..works just fine
Aug 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
6B10 problem
If you still need the user guide, you may find it here: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=12804
I'm afraid that here is already a mechanical problem on your printer if displays 6B10. It's a paper feed sensor error on your printer that means you need to have it serviced with an authorized canon technician.
Hope this helps.
Thanks.
Jul 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma Paper feed not feeding!!
Either the pickup roller needs to be replaced,(a maintenance kit) or the tray isn't pushing the paper high enough to grab. Tyr loading a few more pages in the tray and making sure the tray is seated properly. Then try replacing the roller.
Sep 17, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Pixma mp830
Take it back for a full replacement, it sound like it has a few faults, why be stuck with it, you have the right to fair trading, which states your product must do wahta it should for a reasonable amount of time. Just out of box and faulting already is not reasonable!!! Hope you hace receipt.
Aug 31, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
178 people viewed this question
old marine
old marine
