HPdeskjet630c printer!S DRIVER INSULTION - Office Equipment & Supplies
    President:
  • 828 Answers
Try to find the driver of your printer at this site: www.driverguide.com
Posted on Jun 16, 2009
Driver side parking light stays on even when vehicle is turned off. The blinker is not being left on.i just replaced the housing, the module, the low beam bulb. the rest of the bulbs were switched from the...
The problem is the wiring insulation in the headlight units is breaking down. Remove and check yours. There are lots of complaints about the R/F park light staying on, also complaints of the check lights warning coming on when driving but no bulbs are blown - all lights are working. I traced the fault on my 03 3.2 Touareg to the insulation on the wiring within the headlight had cracked and come away, this would short the park light circuit when the headlamp self leveling system moved within the headlamp units. This would bring up my check lights waning and then after a few more times it would then blow the fuse. I replaced the fuse and found the parklight would now stay on. I traced the fault to the Onboard Power Supply Control unit located under the dash just above the gas pedal. We are right hand drive here in New Zealand so location of this unit may be different for LHD. The driver chip in the control unit was burnt out. Sorced a second hand unit for $350 and swapped the driver chip to my unit (a good auto electrician should be able to test and do this for you) to avoid having the dealership rip me for the reprogamming of the unit to the vehicle. Assembled and tested. Fixed! I also replaced the wiring looms directly behind the headlights as these were also breaking down, they are about 200mm long as the insultion was also cracked and failing. I hope this helps there are lots of post looking for help with this problem
Mar 03, 2011 | 2005 Volkswagen Touareg
Vehicle was driven without issue, parked overnight and next morning would not start. Managed to start with aerostart, drove 50kms to town done shopping then drove to toilets came back out and no start, got...
replace the wires. start with coil lead. the metal end may not be making a good connection with the wire.The conductor can burn away inside the insultion and leave no exterior burns to see. I would remove the metal end and trim back enough insulation to expose about an inch of the carbon impregnated conductor. Then with the conductor folded backwards along the outside of the wire, refit the metal clip tightly. Ensure that plenty of the conductor is held tightly under the clip, about half an inch. The tight fit is all you need to ensure a good contact. Good Luck! Duck
Jan 10, 2011 | Ford Festiva Cars & Trucks
I have power going to instrument panel, fuel pump and injectors when I crank my key , but will not turn over. Took off molding and insultion under steering column to get at ignition switch which is a 3...
Let's start with something simple. Have someone turn the key to the "crank" position while you tap the starter with a hammer to see if it engages. You will probably see that it will engage and start. If this becomes the case, replace the starter. If you need instructions, let me know and I can get these to you.
Jun 14, 2010 | 1994 Oldsmobile Cutlass Supreme
Center console gets hot
I had a 1965 Stingray ,that would melt the bottom of your gummy soled desert boots,back in the sixties
So I will go with poor air flow under the car,which is what you want. You don't want lift. That allows all the engine and drive line heat to transfer into the body. I believe you have that long aluminum drive shaft tube, right under the console, that ties the bellhousing to the rear transaxle. Check to see if some insultion is missing under the body
May 08, 2010 | 2000 Chevrolet Corvette
Jumped my car and the jumper cables started to get hot and melt the insultion.I had at least lights before the jump.After nothing,no dashlights just dead.Put new battery in and still nothing.Did i blow a...
THE JUMPER CABLES WERE OF A TOO LIGHT OF GUAGE WIRE. THERE SHOULD BE A BATTERY FUSE LOCATED IN THE FUSE BOX IN THE DRIVERS SIDE ENGINE COMPARTMENT.
Dec 16, 2009 | 2002 Mazda Protege
I have A 2006 KTM85 SX BUT DOES NOT HAVE SPARK WHEN I TRY TO START IT
make sure spark plug is tight,if that is not it pull plug and ground it to see if you have spark,also make sure plug is not fouled,then check ignition coil,that if there are two primary wires make sure there are connected and power is getting to them.if you have just one wire coil is internally ground check for insultion breakdown also make sure your plug wire is good
Jul 01, 2009 | 2008 KTM 105 XC
Whirlpool side by side refridgerator doors rusting
sounds like an older refrig, we call that "refrigerator cancer", its rusting from the inside out. your inner insultion has become saturated w/ moisture and is just rusting away now, you can try covering witha rustolem might buy you some time only other way is to replace entire door and thats a few hundred dollars
Feb 20, 2008 | Whirlpool GS6NBEXR Side by Side...
Video camera driver
conecto mi cam a mi pc y me pìde el controlador donde lo encuentro
Jan 15, 2008 | Vivitar ViviCam 35 Digital Camera
k24674
jasbo
jasbo
Marvin
Marvin
