Question about Panasonic PT-53WX42 53" Rear Projection Television
Pt47wx42 convergence The blue gun on the bottom half of the picture won't converge with the other guns. This is not a minor difference. It is way off and has actually formed an arc across the bottom. It happened when I pressed aspect ratio on the remote. Any ideas? Thanks for the reply.
  • 126 Answers
Yes, I have and idea, and it has nothing to do with the aspect ratio. One of the convergence output IC's has failed. This is a very common failure with all projection sets. Average repair cost by a reputable repair shop is around $200 to $300 depending on where you live. BTW that set is well worth the repair cost.
Posted on Jun 16, 2009
  • Panasonic Master
  • 3,459 Answers
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jul 22, 2009
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
CONVERGENCE RED GUN
check these sites , you would have a better conclussion, better check with a local professional, so that he would fix your problem,its only a minor fault..
http://myweb.accessus.net/~090/how2adj.html
http://www.anatekcorp.com/faq/archprotv.htm
Dec 10, 2007 | Toshiba 50HDX82 50" Rear Projection...
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Curved picture top an bottom
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 04, 2009 | Samsung HCN4727W 47" Rear Projection...
Blue Projection Gun
It is not the gun ,but the convergence IC that needs replaced providing that you have went into the tv menu and selected convergence and manually adjusted the blue convergence.
Sincerely the Hammerman
May 14, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Blue color gun off line
Milt,
What are you referring too when you ay the blue color gun is offline? Is the blue crt not lighting? Or just the convergence alignment off??
Bill
Nov 23, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Right side convergence
A convergence IC has burned out. If I remember correctly, those Pioneer sets have one huge convergence IC, but that IC only has 5 channels in it so they use another smaller dual STK IC and one half of it is used for the 6th channel and the other half is the vertical output. Look on the convergence board, find the blue convergence jack, identify the blue horizontal channel, follow the traces and replace the IC handling the blue horizontal channel.
Aug 28, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Aug 10, 2007 | JVC AV-56WP74 56" Rear Projection...
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
Bent image
Excelent description,whats happening is your set starts to show a blue convergence problem and is only correctable by replacing the blue convergence amplifier IC,the set has 3,one for each color,not all of them develope problems but they all develope loose conections,after the IC has been replaced there are adjustments to do.If you are familiar with tv service this information will give a place to start but if you are not too familar be safe and call a servicer to help you.Lets US know how it goes.
Oct 13, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
191 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
