Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My cub cadet 1046 belt keeps coming off, the metal arm that comes out over the mower deck is really worn where the bolt belongs.
5 Suggested Answers
  • 109 Answers
SOURCE: Noisey Cub Cadet mower
If the noise is coming from the deck, locate the idle pulley on the deck. there should be 1 or 2 rubber "bumpers" at the opposite end of the pulley arm where it meets the "j" pin. If they are missing, it will make a loud metal to metal sound.
Posted on Apr 22, 2009
  • 376 Answers
SOURCE: diagram of mower deck
Go to... http://www.partstree.com/parts/ Then click on Cub Cadet, enter the model number then all the diagram are there.
Posted on Jul 04, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
vincob
  • 718 Answers
SOURCE: I need a mower deck belt diagram for cub cadet
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Posted on Aug 14, 2010
How do I remove mower deck on 3200 cub cadet
Lower deck all the way down. In the back you will see where the arms come down. Look on the arms and remove the pins then slide the deck forward to get it off the front deck arm. Remove belt from engine pulley
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
Oct 10, 2015 | Cub Cadet Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Cub cadet belt keeps coming off the deck
Link to see video of the Fix for cubcadet deck belt coming off can be viewed here: http://www.youtube.com/watch?v=Pd4nYovcnvY
Apr 21, 2012 | Cub Cadet Garden
1046 cub done 120hrs 12mths old replaced all pullies bearing use 5 belts in 12mths belts keep comeing off is this a problem with this modle 2009
hi,
on some cubs there are two holes for the spring loaded pulley adjustment arm. take the deck back off and look at the spring loaded pulley arm mechanism, if theres two holes , take the bolt out that holds the adjustment arm down and move it to the other hole. theres two holes for the spring too, try the other hole, make sure your spring isnt upside down. putting the spring back on is difficult. connect it to the front first then come around the back with a spare piece of rope, put it on the spring and pull on the rope to get the spring back on the mower deck. use eye protection and be careful.
jm
Apr 23, 2011 | Cub Cadet LTX1040 Deck Belt 2009 Only...
Cub cadet from a 1330 lawn tractor drive belt keeps coming off
Most common problem is the deck bearings being bad for one of the blades. The next thing to look at is the mounting arms, hsake the deck back and forth if it wiggles side to side it will need reparirs. Also check that yo have not bent any pullys and that they are all running straight.
Aug 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet model LT1045 belt coming off the pulley for cutting deck?
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING!
I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing.
Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw.
It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!!
- Mike
If you for some reason you cant
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Apr 22, 2009 | Cub Cadet Street Sign- tractor lawn riding...
How do you replace the mower belt on a cub cadet?
check the alignment of the ideler pully to make sure it is even withe the drive pulleys. if not in line it will cause the belt to break. There is a spacer that is on the idler that should be on top and not on the bottom of the pully.
Apr 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
549 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
